  3. How to highlight the net which does not contains the alphanumeric...
  • Subscribers 163
  • Views 14973
How to highlight the net which does not contains the alphanumeric number in the pins?
krthik15
krthik15 over 7 years ago
Hi All,
In my design has two components COMP1 and COMP2 . COMP1 pin number is only number (1,2,3..) . COMP2 pin number is only alphanumeric(A1,A2...) . i want to find out the net which is connected to only COMP1.
How to highlight the net which does not contains the alphanumeric number in the net pins?
procedure( _nname()
axlSetFindFilter(?enabled list("noall"))
axlSetFindFilter(?enabled "Nets" ?onButtons "Nets")
axlSelect()
net = car(axlGetSelSet())
foreach(branch, net ->branches
foreach(child, branch ->children
when(child ->objType == "pin"
pins= cons(child, pins)
pin_nums = ()
foreach(one pins
pin_num = one->number
pin_nums = cons(pin_num pin_nums)
*pin_nums = ( "458" "H5" "1" "71" "76" "79" "84" "86" "90" "95" "98" "103" "108" "113" "116" "121" "127" "132" "135" "140" "K1" )
karthik
  • DE202408202727
    DE202408202727 over 7 years ago +1
    defun( HighlightMyNets () comp1 = axlDBFindByName('refdes "COMP1") comp1nets = comp1 ->pins ~>net comp2 = axlDBFindByName('refdes "COMP2") comp2nets = comp2 ->pins ~>net nets = setof(net, comp1nets…
  • DE202408202727
    nets = setof(net, comp1nets, !member(net, comp2nets))
    axlHighlightObject(nets)
  • krthik15
    krthik15 over 7 years ago in reply to DE202408202727
    Thanks Dave!
