  3. Smp (surface mount pad ) without via
  • Replies 8
  • Views 17770
vimaldevlpr
vimaldevlpr over 7 years ago
Hai
Were in the .brd file i want to highlight the  smp pad  if  it not  connected with via. i don't know how to do it using in skill any one share me the skill code please.
  • vimaldevlpr
    vimaldevlpr over 7 years ago in reply to DavidJHutchins
    Hai David kindly thanks for your reply and support  and one more thing now also some problem found.
    Here the two smd are connected by trace but there is  no via in this  two pins i want to check fan out only here in this two smd pins has no fanout but it is not highlighting can you please check it.
  • DavidJHutchins
    DavidJHutchins over 7 years ago in reply to vimaldevlpr
    Below is my final iteration of this code ( I removed highlighting single-pin nets )
    procedure(Hilite_UnConnectedPins(@optional (SmdOnly nil))
    let((NetPinCnt PinCnt PinList ViaList)
    (PinCnt=0)
    if(SmdOnly then
    axlMsgPut("SMD only")
    else
    axlMsgPut("all pins")
    foreach(net (axlDBGetDesign)->nets
    (NetPinCnt = 0)
    foreach(branch (net->branches)
    (PinList = setof(c (branch->children) ((c->objType) == "pin")))
    (ViaList = setof(c (branch->children) ((c->objType) == "via")))
    (NetPinCnt = NetPinCnt + length(PinList))
    ; when(and(eq(1 length(PinList)) eq(0 length(ViaList)))
    ; if(SmdOnly then
    ; unless(car(PinList)->isThrough
    ; axlHighlightObject(car(PinList) t)
    ; PinCnt++
    ; else
    ; PinCnt++
    when(eq(0 length(ViaList))
    if(SmdOnly then
    (ViaList = setof(c PinList ((c->isThrough) == t)))
    axlHighlightObject(PinList t)
    (PinCnt=PinCnt+length(PinList))
    else
    when(eq(1 length(PinList))
    PinCnt++
    when(and(eq(1 NetPinCnt) SmdOnly)
    axlDehighlightObject(PinList t)
    PinCnt--
    axlMsgPut("%d Pins Highlighted" PinCnt)
  • vimaldevlpr
    Thanks a lot david
