  3. Smp (surface mount pad ) without via
  • Replies 8
  • Views 17769
vimaldevlpr
vimaldevlpr over 7 years ago
Hai
Were in the .brd file i want to highlight the  smp pad  if  it not  connected with via. i don't know how to do it using in skill any one share me the skill code please.
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    Below is a simple function that will highlight unconnected pins
    procedure(Hilite_UnConnectedPins()
    let((PinCnt)
    (PinCnt=0)
    foreach(net (axlDBGetDesign)->nets
    foreach(branch (net->branches)
    when(eq(1 length(branch->children))
    foreach(child (branch->children)
    when(((child->objType) == "pin")
    axlHighlightObject(child t)
    PinCnt++
    axlMsgPut("%d Pins Highlighted" PinCnt)
  • vimaldevlpr
    vimaldevlpr over 7 years ago in reply to DavidJHutchins
    Hai david thanks for your reply i want to highlight if the smd didn't have fan out
    This is fan out smd pin
    In this image didt have a fanout if it like this means i want to highlight
    For this can you share me the code please.
  • DavidJHutchins
    I added an option argument to the function to limit the highlighting to smd pins, below is the journal file entries from the test run:
    Command > hilite_unconnectedpins t
    SMD only
    426 Pins Highlighted
    110 Net(s) dehighlighted..
    all pins
    528 Pins Highlighted
    Command >
    the updated code is shown below:
    procedure(Hilite_UnConnectedPins(@optional (SmdOnly nil))
    let((PinCnt)
    (PinCnt=0)
    if(SmdOnly then
    axlMsgPut("SMD only")
    else
    axlMsgPut("all pins")
    if(child->isThrough then
    unless(SmdOnly
    PinCnt++
    else
    PinCnt++
    )axlCmdRegister( "Hilite_UnConnectedPins" 'Hilite_UnConnectedPins ?cmdType "general")
  • vimaldevlpr
    Hai david thanks for your reply but some smd pins are not showing.
    Here in this image it has a branch but didn't have an via it is not highlighting  i want to check fanout but it is not showing can you please re correct the code please.
  • DavidJHutchins
    DavidJHutchins over 7 years ago in reply to vimaldevlpr
    OK, below is the 3rd iteration of this code:
    let((PinCnt PinList ViaList)
    (PinCnt=0)
    if(SmdOnly then
    else
    (PinList = setof(c (branch->children) ((c->objType) == "pin")))
    (ViaList = setof(c (branch->children) ((c->objType) == "via")))
    when(and(eq(1 length(PinList)) eq(0 length(ViaList)))
    if(SmdOnly then
    unless(car(PinList)->isThrough
    axlHighlightObject(car(PinList) t)
    PinCnt++
    else
    PinCnt++
