  3. Staggered circle shape array in a circular ring range
  • Subscribers 159
  • Views 15078
Jason Hsu
Jason Hsu over 6 years ago
  I have one arithmetic question for staggered circle shape in a circular ring range. The radius of the circle shape is 7mil,center to center is 22mil. I want to add a staggered array in a area. But How to judge the staggered array lies in the range of circular ring?How to delete the circle shape out of the circular ring?The bBox only operate on rectangle,Anybody have a good method or sample code?Any help is appreciate,thanks in advance.
Best Regards
Jason
  • eDave
    eDave over 6 years ago
    It's difficult to understand your question. Maybe post an image.
  • Jason Hsu
    Jason Hsu over 6 years ago in reply to eDave
    Hi Dave,
        Thank you very much for your quickly reply. My question is the following picture.
        I want to add many circle shape on one layer in the range of donuts. These circle shape is 7 mil radius, center to center is 22 mil. The donut's inner diameter & outside diameter is R1 & R2. I can add these circle as an staggered array, but how to delete the circle shape lies in R1 & outside R2? The bBox area only operate for rectangle as I known. For the pin 1~8, because they are small area, I can treat them as small rectangle. Delete the circle shape in the small area. I don't know if my expression is clear, but if do you have any method or sample code for me? Please help me, thanks a lot.
    Jason
  • eDave
    eDave over 6 years ago in reply to Jason Hsu
    Ok. Now it makes sense.
    Create two polygons:
    1/ with the inside diameter (R1) plus 7mils (using axlPolyExpand if necessary)
    2/ with the outside diameter (R2) less 7mils (using axlPolyExpand if necessary)
    Now use axlGeoPointInShape using the centre of each array circle to see if each circle is inside R2 and outside R1.
    You could also use axlPolyOperation commands but this would be much slower.
    I hope this helps.
  • eDave
    eDave over 6 years ago in reply to eDave
    Of course it would be even easier to do this mathematically. Given that you know the donut's dimensions, a circle will fall fully inside the donut if its distance from the centre of the donut is between R1 - 7 and R2 + 7
  • Jason Hsu
    Thank you, Dave. I will try it later. I always can learn many ting from you. Thanks again.
