  3. BB Via Net name report
  • Views 15228
vimaldevlpr
vimaldevlpr over 7 years ago
Hai,
I  want to get bb via net name report i used some codes but it shows all present via i want only bb via can you please re correct the code i will attach the code below.
axlCmdRegister( "ViaReport" `ViaReport)
(defun ViaReport ()
; Find all of the vias in the design
allViasInDesign=list()
originalVisible=axlVisibleGet()
designName = axlCurrentDesign()
axlVisibleDesign(t)
axlShell("redisplay")
axlSetFindFilter(?enabled '(noall vias) ?onButtons '(noall vias))
allViasInDesign=axlGetSelSet(axlAddSelectAll())
axlClearSelSet()
; Open a file to work on
if(length(allViasInDesign)==0
then
axlUIConfirm("No vias in this design. Please try another design.")
else
writeOutFile = outfile("./DesignViaReport.csv" "w")
fprintf(writeOutFile strcat("Design Via Report for " designName "\n\n"))
fprintf(writeOutFile "Via Location,Via Net Name,Padstack Name,Via Start
Layer,Via End Layer\n")
; Output data for each via to the file
foreach(via allViasInDesign
viaLocation = sprintf(nil "%L:%L" car(via->xy) cadr(via->xy))
fprintf(writeOutFile strcat(viaLocation ","))
fprintf(writeOutFile strcat(via->net->name ","))
fprintf(writeOutFile strcat(via->name ","))
fprintf(writeOutFile strcat(car(via->startEnd) ","))
fprintf(writeOutFile strcat(cadr(via->startEnd) "\n"))
);end foreach via allViasInDesign
; Close the file and wrap up
fprintf(writeOutFile "END OF FILE")
close(writeOutFile)
axlVisibleSet(originalVisible)
axlUIConfirm( "Report has been generated in your working directory." )
; This next line launches Excel and displays the report
axlHttp("DesignViaReport.csv")
);end if length(allViasInDesign)==0
);end defun myCompanyViaReport
Its shows all but i want only bb via can any one please re correct the code.
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    try changing the output section of your code to the following to not output vias spanning from Top to Bottom:
    when(or(not(nindex(car(via->startEnd) axlConductorTopLayer())) not(nindex(cadr(via->startEnd) axlConductorBottomLayer())))
    );end when via span not Top to Bottom
  • vimaldevlpr
    vimaldevlpr over 7 years ago in reply to DavidJHutchins
    Thanks a lot..
