  3. How to merge the multiple overlap shapes by single clic...
  • Subscribers 163
  • Views 19289
How to merge the multiple overlap shapes by single click
krthik15
krthik15 over 7 years ago
Hi all,
I can merge the  two overlap shapes in the net by using following code. If number of overlap shapes increases, need to run the command multiple times to merge shapes.
Is there a  way to merge the multiple no of overlap shapes in the net by single click?
#Merge shape code
axlSetFindFilter(?enabled "Nets" ?onButtons "Nets")
while(axlSelect()
net_db = axlGetSelSet()
foreach(net net_db
shapes=()
foreach(branch, net ->branches
foreach(child, branch ->children
when(child ->objType == "shape"
shapes= cons(child, shapes)
);wh
);fe
);fe
l = length(shapes)
s1 = car(shapes)
s2 = cdr(shapes)
s_primary = axlShapeMerge(s1 s2 'quiet)
);while
Thanks in advance,
Karthik
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    I would try replacing the following:
    s1 = car(shapes)
    s2 = cdr(shapes)
    with the code below:
    (setq cnt 0)
    foreach(shp shapes
    when(shp->nSegs > cnt
    (setq cnt shp->nSegs)
    (s1 = shp)
    s2 = remq(s1 shapes)
  • krthik15
    krthik15 over 7 years ago in reply to DavidJHutchins
    Hi David,
    Thanks for the code. I have already tried the same but the problem is , Assume i have 4 shapes in the net so Shape dbid is (S1_db , S2_db, S3_db ,S4_db). While running the code first two shapes are merged and created the merged shape so the DBID had changed it is not in the shapes list. So that i need to run the code multiple times to merge all the shapes.
    karthik
  • DavidJHutchins
    I duplicated your issue this morning, try replacing:
    with the following code:
    (s_result = axlShapeMerge(s1 s2 'quiet))
    foreach(shp s2 unless(shp->nSegs (s2 = remq(shp s2))))
    while(length(s2) > 0
    when(s_result if(listp(s_result) then (s1 = car(s_result)) else (s1 = s_result)) (s_result = axlShapeMerge(s1 s2 'quiet)))
  • krthik15
    Thanks David!!  It's working Well.
  • Sivaji Chowdary
    Sivaji Chowdary over 7 years ago in reply to krthik15
    Hi Karthik,
    Can you upload the complete working code and the way to execute it.
