  3. Dynamics to attach a circle to the cursor during active...
  • Views 13903
Dynamics to attach a circle to the cursor during active command
Andak
Andak over 7 years ago
Hello everyone,
I'm trying to attach a circle to the cursor during an add connect command. The problem is that the cline itself goes blind, ending up only with the little circle. After the first click, the cline comes back while my little circle vanishes.
Is there a way to keep them both undefinetly?
Here is the function I'm using (units mm)
axlCmdRegister("tester" 'testfun ?cmdType "sub_cmd")
(defun testfun ()
    axlClearDynamics() ; Clean out any existing cursor data
    mypath = axlPathStart(list( 0.05:0)) ; Start arc
    axlPathArcCenter(mypath, 0, 0:-0.05, nil, 0:0); Load path into the dynamic cursor buffer
    axlAddSimpleMoveDynamics(0.25:0 mypath "path" ?ref_point 0:0)
Catalin
