  3. Get the height value of the textblock from a brd
  • Views 16594
jancho
jancho over 7 years ago
Hello , I'm a new learner about the pcb skill , there have a issue need your help , thanks in advance!
I want to get the actual height value of the textblock, but now it occur the error when run in brd file.
1.The code is as the following:
defun getheight ()
(prog ()
axlSetFindFilter(?enabled '(noall text) ?onButtons '(noall text))
selBox = axlEnterBox()
axlSingleSelectBox(selBox)
allboxes = axlGetSelSet()
foreach(txt allboxes
    return(txt->textBlock->height)
2.The error in the allegro is as following:
E- *Error* get/getq: first arg must be either symbol, list, defstruct or user type - "3"
The picture below is the instructions about the textblock attributes from skill manual.
  • DE202408202727
    DE202408202727 over 7 years ago
    First you need to get the text block parameter:
    defun( Getheight ()
    let(()
    println(axlGetParam(strcat("paramTextBlock:", txt->textBlock) ->height)
  • jancho
    jancho over 7 years ago in reply to DE202408202727
    Thanks for your kindly help, eDave!
    But it still occur the error info on my side:
    E- *Error* get/getq: first arg must be either symbol, list, defstruct or user type - "paramTextBlock:3"
  • DE202408202727
    DE202408202727 over 7 years ago in reply to jancho
    Sorry, I misssed a bracket:
    Use this line:
    println(axlGetParam(strcat("paramTextBlock:", txt->textBlock)) ->height)
  • jancho
    Thanks eDave!!! It work well now.
