  3. About the text BBOX
  • Replies 7
  • Views 19287
About the text BBOX
jancho
jancho over 7 years ago
Hi all , I have a problem about the text BBOX in skill.
The BBOX get from a text is just a rectangle area , this area actually is more bigger than the text size, and text also not fullly filled the BBOX area.
So if we just use the BBOX to judge if the text overlap with other text or pin/via , it won't be so accurate. If you have some better methods?  Thanks a lot!
(The following green area is the BBOX for text"U123")
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    Yes, that is the flow I would use: if the text BBOX overlaps other objects BBOX, convert the text into line segments & then use axlAirGap to judge if line segments is really too close to the other objects
  • jancho
    jancho over 7 years ago in reply to DavidJHutchins
    Thanks your kindly reply,David! I will try this method.
