  3. About the text BBOX
  • Replies 7
  • Views 19286
About the text BBOX
jancho
jancho over 7 years ago
Hi all , I have a problem about the text BBOX in skill.
The BBOX get from a text is just a rectangle area , this area actually is more bigger than the text size, and text also not fullly filled the BBOX area.
So if we just use the BBOX to judge if the text overlap with other text or pin/via , it won't be so accurate. If you have some better methods?  Thanks a lot!
(The following green area is the BBOX for text"U123")
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    Then try using axlText2Lines() to convert the text string into line segments for each character, then check the spacing from those segments to the other objects
  • jancho
    jancho over 7 years ago in reply to DavidJHutchins
    Thanks David! I checked the skill manual , the function seems can't return the arc line segments , is it right?
  • DavidJHutchins
    DavidJHutchins over 7 years ago in reply to DavidJHutchins
    it doesn't return arc data since text is drawn strictly as line stroke segments per the data in $CDSROOT/share/pcb/text/ansifont.dat
  • jancho
    It seems still can't solve the text BBOX issues completely.  ~_~
  • jancho
    Hi David , I'm thinking about this method now: first , use the text BBOX to judge if there have some other things(text,pin, via ,solder...) in the text'BBOX area, then use the function axlAirGap to judge if text really intersected with other things.
    How about this method?
