  3. Create external DRC for different plating spacing
  • Views 15439
ENEGUE
ENEGUE over 7 years ago
Hi Guys,
Any idea how to create external DRC to cater the spacing between two type of plating.
Component 1: ENIG plating,(Package geometry/Gold_top are use for this defination)
Component 2: OSP plating,( define by overlap area between soldermask and metal layer in padstack)
Eugene
  • DE202408202727
    DE202408202727 over 7 years ago
    axlAirGap should be able to be used to calculate the spacing.  Then use axlDBCreateExternalDRC to create the drc.
  • ENEGUE
    ENEGUE over 7 years ago in reply to DE202408202727
    Yup,
    but it will took sometime to regenerate the overlap shape before apply axlAirGap especially when got alot of component, any way to generate the overlap area dbid without generate shape?
    Eugene
  • DE202408202727
    DE202408202727 over 7 years ago in reply to ENEGUE
    I don't have time to look at this thoroughly but you should be able to use the anlyLayer option of axlAirGap to avoid creating the shape.
  • ENEGUE
    Thanks for your input Dave..=)
    Eugene
