  3. brd2odb with the substitute padflash option to remove top...
  • Views 14559
brd2odb with the substitute padflash option to remove top and bottom pads from odb++ output??
HJerry
HJerry over 7 years ago
Hi all,
We are trying to remove the pads on external layers during brd2odb.
I tried the -p option, but doesn't seem to change anything.
I added a thermal model file an added the -tf and -tm options, now brd2odb starts then stops right away.
Here is a snippet of the code:
OdbInstallDir = axlGetVariable("ALLEGRO_BRD2ODB")
LayoutSite = axlGetVariable("allegro_site")
odbcfgFile = strcat(LayoutSite "/j_share/odb++.config")
full_path = axlGetDrawingName()
odb_jobname = strcat(axlCurrentDesign() "_odb++" )
board_path = getWorkingDir()
sprintf(thermMod "%s%s" getWorkingDir() "./MISTAKE.txt")
modname = "MISTAKE"
sprintf(cmd "\"%s/brd2odb.exe\" -sp -bb -sf -a2l -c p -d -cfg %s -gz -ijp %s -jn %s -jp %s -p s -tf %s -tm %s -o 500 -read_sqa no -skip_refdes no -tr_sym yes " OdbInstallDir odbcfgFile full_path odb_jobname board_path thermMod modname)
axlRunBatchDBProgram("brd2odb" cmd ?noUnload t ?noProgress nil ?noLogview t ?noExitMsgs t)
  • HJerry
    I should add, the purpose is to get rid of pads on non-plated through holes.
