  3. In allegro 17.4 HF008, The OK and cancel options of the...
  • Replies 13
  • Views 24000
In allegro 17.4 HF008, The OK and cancel options of the dialog box cannot be displayed normally
Kinzhifeng
Kinzhifeng over 6 years ago
Under the resolution of 1366 * 768 computer screen,
The OK and cancel options of the dialog box cannot be displayed normally,
They are covered by the windows taskbar and cannot be removed !!!
  • DavidJHutchins
    DavidJHutchins over 6 years ago in reply to Kinzhifeng +1
    I had the same issue on my win10 laptop, the vertical screen resolution is < 1024 so the buttons appear off the screen The Allegro default font size is 8, so I added the following to my %home%\pcbenv…
  • Kinzhifeng
    Kinzhifeng over 6 years ago in reply to steve
    It's true that these two dialog boxes are not compatible with my 14 inch 1366 * 768 resolution screen
  • Kinzhifeng
    I believe that other customers with 14 inch 1366 * 768 resolution screen will definitely have this problem
  • Kinzhifeng
    Can this problem be solved?
  • DavidJHutchins
    The Allegro default font size is 8, so I added the following to my %home%\pcbenv\env file:
    set fontsize = 7
    Now those forms are displayed slightly smaller so the buttons now appear on the screen Slight smile
  • Kinzhifeng
    Kinzhifeng over 6 years ago in reply to DavidJHutchins
    Hey brother! Yes, my computer is also a laptop
    thank you! Use your method to set up after some effect, can barely use
    But I hope cadence can fix this bug in the next hotfixSlight smile
