  3. In allegro 17.4 HF008, The OK and cancel options of the...
  • Replies 13
  • Views 23999
In allegro 17.4 HF008, The OK and cancel options of the dialog box cannot be displayed normally
Kinzhifeng
Kinzhifeng over 6 years ago
Under the resolution of 1366 * 768 computer screen,
The OK and cancel options of the dialog box cannot be displayed normally,
They are covered by the windows taskbar and cannot be removed !!!
  • DavidJHutchins
    DavidJHutchins over 6 years ago in reply to Kinzhifeng +1
    I had the same issue on my win10 laptop, the vertical screen resolution is < 1024 so the buttons appear off the screen The Allegro default font size is 8, so I added the following to my %home%\pcbenv…
  • Kinzhifeng
    In addition, there are also problems in the options -- preferences dialog box of OrCAD 17.4 capture
  • RFinley
    RFinley over 6 years ago
    (haven't installed my license update yet.)
    You're not able to grab the top of that window and slide it down?
    And, are you sure that is the native resolution of your laptop display?
    In all seriousness, why not get a new laptop?
    • Vote Up -1 Vote Down
  • Kinzhifeng
    Kinzhifeng over 6 years ago in reply to RFinley
    Hey, guy! There is no problem with my computer. 1366*768 is the standard resolution of my computer, and I don't need to change it. I tried to pull down from the top of the window and it didn't work. Are you sure your 1366*768 resolution computer is displaying normally?
  • steve
    steve over 6 years ago in reply to Kinzhifeng
    Close PCB Editor, open a Windows file Explorer window and type %HOME% into the address bar followed by a return. This will open your HOME folder (usually C:\SPB_Data). Go into the pcbenv folder and delete the allegro.geo file then restart PCB Editor and see if that helps.
  • Kinzhifeng
    Kinzhifeng over 6 years ago in reply to steve
    The deletion of C:\SPB_Data is still the same. It has nothing to do with this.
