  3. Checking Arc in trace.
  • Views 19990
vimaldevlpr
vimaldevlpr over 6 years ago
Hai.
I want to check the arc present in trace or not  if not means i want to highlight the trace using skill program i am new to skill can any one please guide me or share me the code please.
sample images
1.Correct trace:
2. Highlight trace:
Here it is an sample images if the trace like in 2nd image i want to hightlight the trace can any one please share me the code.
  • luanvn81
    luanvn81 over 6 years ago in reply to vimaldevlpr
    Fullscreen 2548.clineanglecheck.txt Download
    ;## 1-SKILL CHECK Angle of Cline seg on the Cline#
    axlCmdRegister( "csa" `csa)
    (defun csa ()
    	originalVisible=axlVisibleGet()
    	designName = axlCurrentDesign()
    	design_path = axlGetDrawingName()
    	design_unit = car(axlDBGetDesignUnits())
    	AllObject=list()
    	drc = 0
    	stop = nil
    	logWindow = nil
    	max_angle = 90.0
    	axlSetFindFilter(?enabled '(noall CLINES) ?onButtons '(noall CLINES))
    	mypopup = axlUIPopupDefine(nil	(list (list "Done" 'axlFinishEnterFun) (list "Cancel" 'axlCancelEnterFun)))
    	axlUIPopupSet( mypopup)
    	while(axlSelect(?prompt "Please select Cline...")
    		AllObject = axlGetSelSet()
    		axlClearSelSet()
    		if(logWindow != nil then
    			axlUIWClose(logWindow)
    			if(isFile("Clineseg_angle.log") == t then deleteFile("Clineseg_angle.log"));end if
    			logWindow = nil
    		);end if
    		drc = 0
    		WriteOutFile = outfile("./Clineseg_angle.log" "w")
    		fprintf(WriteOutFile, "Design name: %s\n", design_path)
    		fprintf(WriteOutFile, "Angle Check: %f\n", max_angle)
    		fprintf(WriteOutFile, "%s %s\n", "Check Date:", timeToString(fileTimeModified("Clineseg_angle.log")))
    		fprintf(WriteOutFile, "%s\n", "------------------------------------------------")
    		fprintf(WriteOutFile, "%-14s %-10s %s\n", "Layer", "Angle", "Locations")
    		foreach(object AllObject
    			Netname = object->net->name
    			Layer = object->layer
    			drcLayer = strcat("DRC ERROR CLASS/", cadr(parseString(Layer, "/")))
    			Cline_Segments = object->segments
    			while(length(Cline_Segments) > 1
    				First_seg = car(Cline_Segments)
    				Second_seg = nthelem(2,Cline_Segments)
    				First_seg_width = First_seg->width
    				Second_seg_width = Second_seg->width
    				if(First_seg_width < Max_LW || Second_seg_width < Max_LW then
    					First_seg_length = axlDistance(car(First_seg->startEnd) lastelem(First_seg->startEnd))
    					Second_seg_length = axlDistance(car(Second_seg->startEnd) lastelem(Second_seg->startEnd))
    					Third_seg_length = axlDistance(car(First_seg->startEnd) lastelem(Second_seg->startEnd))
    					aa = First_seg_length*First_seg_length
    					bb = Second_seg_length*Second_seg_length
    					cc = Third_seg_length*Third_seg_length
    					ab2 = 2*First_seg_length*Second_seg_length
    					CosC = (aa + bb - cc)/ab2
    					AngleInDegree = axlRadToDeg(acos(CosC))
    					;### CONG THUC TINH GOC _axlAngleBetweenLines(list(pt1, pt2), list(pt3, pt4))  =>CHUA TEST THU
    					if(AngleInDegree <= max_angle then
    						fprintf(WriteOutFile, "%-14s %-10.2f %L\n", Layer, AngleInDegree, car(Second_seg->startEnd))
    						actual_text = sprintf(actual_text "%.2f", AngleInDegree)
    						drc_text = sprintf(drc_text "No Permit Angle In Cline")
    						drc_maker = axlDBCreateExternalDRC(list(drc_text sprintf(nil "%.3f", max_angle)), car(Second_seg->startEnd), drcLayer , list(First_seg Second_seg) , nil , actual_text)
    						drc = drc + 1
    					;else
    					;	printf("%L\n", AngleInDegree)
    					);end if
    				);end if seg_width
    				Cline_Segments = cdr(Cline_Segments)
    			);end while i> 1
    		);end foreach clines AllObject
    		; Close the file and wrap up
    		fprintf(WriteOutFile, "%s\n", "END OF FILE")
    		close(WriteOutFile)
    		printf("Process done!\n")
    		axlVisibleSet(originalVisible)
    		axlShell("redisplay")
    		if(drc > 0 then
    			logWindow = axlUIViewFileCreate("Clineseg_angle.log" "Angle report..." nil );t xoa file sau khi xem, nil khong xoa
    		else
    			printf("No Error Found!\n")
    			if(isFile("Clineseg_angle.log")  then deleteFile("Clineseg_angle.log"))
    		);end if
    		printf("Please select Cline...\n")
    	);end while
    );end defun Clineseg_angle
     Hi!
      I have written small code to do this, you can try it.
    Luan.
