  3. Checking Arc in trace.
  • Views 19984
vimaldevlpr
vimaldevlpr over 6 years ago
Hai.
I want to check the arc present in trace or not  if not means i want to highlight the trace using skill program i am new to skill can any one please guide me or share me the code please.
sample images
1.Correct trace:
2. Highlight trace:
Here it is an sample images if the trace like in 2nd image i want to hightlight the trace can any one please share me the code.
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    I wrote this example this morning while waiting for data from an engineer...
    procedure((check_dp_arcs)
    let((Cnt PathList ArcList)
    (Cnt = 0)
    foreach(dp (axlDBGetDesign)->diffpair
    (PathList = list())
    (ArcList = list())
    if( equal((car(dp->groupMembers)->objType) "net") then
    foreach(branch (car(dp->groupMembers)->branches)
    (PathList = append(setof(c (branch->children) ((c->objType) == "path")) PathList))
    else
    foreach(net (car(dp->groupMembers)->groupMembers)
    foreach(branch (net->branches)
    if( equal((cadr(dp->groupMembers)->objType) "net") then
    foreach(branch (cadr(dp->groupMembers)->branches)
    else
    foreach(net (cadr(dp->groupMembers)->groupMembers)
    foreach(path PathList
    ;(ArcList = append(setof(c (path->segments) ((c->objtype) == "arc")) ArcList))
    foreach(seg path->segments
    when(((seg->objType) == "arc")
    (ArcList = cons(seg ArcList))
    axlMsgPut("Net %s length PathList %d ArcList %d" car(dp->groupMembers)->name length(PathList) length(ArcList))
    when(eq(length(ArcList) 0)
    (axlHighlightObject car(dp->groupMembers) nil)
    (axlHighlightObject cadr(dp->groupMembers) nil)
    (Cnt++)
    axlMsgPut("%d diffpairs highlighted" Cnt)
  • vimaldevlpr
    vimaldevlpr over 6 years ago in reply to DavidJHutchins
    Thanks a lot
  • vimaldevlpr
    Hai David
    I Need an one more help I want to check the 90 deg bends in the  trace. if the trace has an 90 degree bend means have to highlight it.
    Can you please recorrect the code.
    vimal
  • DavidJHutchins
    DavidJHutchins over 6 years ago in reply to vimaldevlpr
    I wrote some skill code for a previous employer that did this, it was pretty complex...
    A simpler solution would be to use the 'acute angle' checks added in 17.2 to add drc flags to those locations
  • vimaldevlpr
    Hai David
    Kindly Thanks for your reply but i have to check this in 16.6 tool is there a any other way to find it please guide me.
