  3. Shape segment Airgap
  • Views 16744
vimaldevlpr
vimaldevlpr over 6 years ago
I want to check  air gap between the shape segments if the air gap between shape segments below 50 mil I have to highlight I used some codes by past forum quires. I attached the code  below its not working can any one please re correct the code. I am new to skill.
code:
(defun shp_seg ()
    AllVoidsInDesign = list()
    axlSetFindFilter(?enabled '(noall SHAPESEGS) ?onButtons '(noall SHAPESEGS))
    axlClearSelSet()
    mypopup = axlUIPopupDefine( nil
    (list (list "Done" 'axlFinishEnterFun)
    (list "Cancel" 'axlCancelEnterFun)))
    axlUIPopupSet( mypopup)
    AllVoidsInDesign = axlGetSelSet(axlSelect(?prompt "Select a void..."))
    axlClearSelSet()
    if(length(AllVoidsInDesign)== 0 then
        axlUIConfirm("No Void selected. ")
    else
       foreach(void AllVoidsInDesign
    void_bBox = void->bBox
  void_bBox_x1 = xCoord(car(void_bBox))
  void_bBox_y1 = yCoord(car(void_bBox))
  void_bBox_x2 = xCoord(lastelem(void_bBox))
  void_bBox_y2 = yCoord(lastelem(void_bBox))
  void_xy = axlDBAltOrigin('center void)
  void_size_x = max(void_bBox_x1, void_bBox_x2) - min(void_bBox_x1, void_bBox_x2)
  void_size_y = max(void_bBox_y1, void_bBox_y2) - min(void_bBox_y1, void_bBox_y2)
  if(void_size_x > 50 || void_size_y > 50 then
  add_value_list = void->bBox
  check_area = list(axlMXYSub(car(void_bBox) add_value_list) axlMXYAdd(lastelem(void_bBox) add_value_list))
  axlVisibleDesign(nil)
  axlShell("redisplay")
  axlSetFindFilter(?enabled '(noall SHAPESEGS ) ?onButtons '(noall SHAPESEGS))
  data_in_box = axlGetSelSet(axlSingleSelectBox(check_area))
  axlClearSelSet()
  if(length(data_in_box) > 0 then
   foreach(item data_in_box
   air_gap = axlAirGap(void item nil 'anyLayer)
   if(air_gap < 50 then
    axlHighlightObject(item)
    fprintf(writeOutFile "%L %L\n", air_gap, void_xy)
   );end if
   );end foreach
  );end if
 );end if
vimal
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    I corrected a few errors in your code so it at least works now ( code shown below )
    procedure(shp_seg()
    let((AllVoidsInDesign mypopup void_bBox_x1 void_bBox_y1 void_bBox_x2
    void_bBox_y2 void_xy void_size_x void_size_y add_value_list
    air_gap check_area data_in_box void_bBox writeOutFile
    err_cnt win_id
    (err_cnt = 0)
    (AllVoidsInDesign = list())
    (axlSetFindFilter ?enabled '(noall SHAPESEGS) ?onButtons '(noall SHAPESEGS))
    (axlSetFindFilter ?enabled list("noall" "voids" "INVISIBLE") ?onButtons list("noall" "voids"))
    (axlClearSelSet)
    (mypopup = (axlUIPopupDefine nil list(list("Done" 'axlFinishEnterFun) list("Cancel" 'axlCancelEnterFun))))
    (axlUIPopupSet mypopup)
    (AllVoidsInDesign = (axlGetSelSet (axlSelect ?prompt "Select a void...")))
    (axlClearSelSet)
    if(zerop(length(AllVoidsInDesign)) then
    (axlUIConfirm "No Void selected. ")
    else
    (writeOutFile = outfile("shp_segs.rpt" "w"))
    (void_bBox = (void->bBox))
    (void_bBox_x1 = (xCoord car(void_bBox)))
    (void_bBox_y1 = (yCoord car(void_bBox)))
    (void_bBox_x2 = (xCoord (lastelem void_bBox)))
    (void_bBox_y2 = (yCoord (lastelem void_bBox)))
    (void_xy = (axlDBAltOrigin 'center void))
    (void_size_x = (max(void_bBox_x1 void_bBox_x2) - min(void_bBox_x1 void_bBox_x2)))
    (void_size_y = (max(void_bBox_y1 void_bBox_y2) - min(void_bBox_y1 void_bBox_y2)))
    if(((void_size_x > 50) || (void_size_y > 50)) then
    (add_value_list = (void->bBox))
    ;(check_area = list((axlMXYSub car(void_bBox) add_value_list) (axlMXYAdd (lastelem void_bBox) add_value_list)))
    (axlVisibleDesign nil)
    (axlShell "redisplay")
    ;(data_in_box = (axlGetSelSet (axlSingleSelectBox check_area)))
    (data_in_box = (axlGetSelSet (axlSingleSelectBox add_value_list)))
    (axlClearSelSet)
    if((length(data_in_box) > 0) then
    (air_gap = (axlAirGap void item nil 'anyLayer))
    if((air_gap < 50) then
    (err_cnt++)
    (axlHighlightObject item)
    fprintf(writeOutFile "%f (%f %f)\n" air_gap car(void_xy) cadr(void_xy))
    ;axlShowObject(AllVoidsInDesign)
    fprintf(writeOutFile "\n%d errors found\n" err_cnt)
    close(writeOutFile)
    (win_id = axlUIViewFileCreate("shp_segs.rpt" "shp_segs.rpt" t))
  • vimaldevlpr
    vimaldevlpr over 6 years ago in reply to DavidJHutchins
    Hai david kindly thanks for your reply some errors or not showing can you please check this i will attach the image below here the other segment air gap is less then 50 but it is not showing error or highlighting.
    Thanks again can you please recorrect the code.
  • luanvn81
    luanvn81 over 6 years ago in reply to vimaldevlpr
    Hi! I'm not pro-skiller but  maybe you have selected  shapesegs in void' box, it will return only  shapesegs within selected voids, all voidsegs will be not selected. That maybe reason some errors not be shown?.
    Luan.
  • vimaldevlpr
    vimaldevlpr over 6 years ago in reply to luanvn81
    Thanks a lot luan..
