  3. Import gerbers from Altium to PCB Editor 16.6
  • Replies 13
  • Subscribers 169
  • Views 26240
AsaHer
AsaHer over 6 years ago
Hi.
I work with ORCAD PCB Designer Professional 16.6. I tried to import gerbers from altium (with .GBL, . GBS, .GML, .GTL, .GTO, .GTP, .GTS) but I couldn't.
So, it is possible to import that altium gerber files to this version of PCB Editor?
  If it is possible, how can I do that?
And if it is not possible, it is possible in other version of PCB Editor or do I need some tool independently PCB Editor version?
  • CadAce2K
    CadAce2K over 6 years ago +1
    Hi. In my experience Orcad/Allegro is pretty finicky when it comes to importing gerbers. I've come to not even attempt it. Why don't you just get the Altium database and convert that? Good day.
  • UlfK
    UlfK over 6 years ago +1
    I was once asked to convert an existing design that was only available as Gerber files and a schematic in paper form. I had to create the schematic again in OrCAD Capture and then used a gerber viewer…
  • B Bruekers
    B Bruekers over 6 years ago +1
    Allegro/Orcad PCB only supports gerber files which were exported by Allegro/Orcad... There are small format differences, like how the coordinates are stored. You can manually edit these to match the formatting…
  • AsaHer
    AsaHer over 6 years ago in reply to B Bruekers
    Thanks. Is there some tool that allows you to export gerbers from altium to orcad withput erros?
  • CadAce2K
    CadAce2K over 6 years ago in reply to AsaHer
    CAM350?
  • djs42
    djs42 over 6 years ago
    This is possible, but requires a lot of work. As others point out Allegro likes to import only Allegro "flavor" gerber files so you may need to massage the gerber prior to import. Depending on what you are attempting to accomplish a CAM tool might be a better choice or possibly importing DXF files to use as guidelines. Another note: I have a number of Allegro designs that I had to import foreign gerber into and the design files become huuuuuge to the extent that you'll start encountering design database issues unless you delete the gerber prior to post-processing / data output.
  • AsaHer
    AsaHer over 6 years ago in reply to djs42
    Thanks for the information
  • cdlep
    cdlep over 6 years ago in reply to AsaHer
    CAM tools are the best solution for foreign gerbers.  I am currently using Viewmate Pro for these things as well as for gerber, drill, and ODB++ file comparisons.  It allows you to load two files with the same name but different sources.
