  3. Mismatch in components location between pick/place file...
  • Views 3084
Mismatch in components location between pick/place file and OBD file
pradihegde25
pradihegde25 over 6 years ago
Hello All
Greetings..
I have designed a PCB with the components on both TOP and bottom layer . Generated OBD++ and pick/place file. But the Assembly house is reporting that the ODB++ file generated from PCB is showing that all the component location is TOP on their tool (CAD CAM Professional). where as the pick/place file shows the bottom components correctly as "m" orientation.
Not sure why the OBD++ file is showing wrong positions. Kindly help.
Tool: PCB Designer professional 16.6 ( with ODB++ inside)
Regards
Pradeep
  • CadAce2K
    CadAce2K over 6 years ago
    Hi. I've never encountered that problem with ODB++, sorry. I'm currently running 17.2 and still no issues. I suspect it's the assembly house's issue, not yours.
    When you generate the ODB++ do you also review the ODB++ data when you do the output? That should show you that the component orientation is correct.
  • pradihegde25
    pradihegde25 over 6 years ago in reply to CadAce2K
    Thanks for the reply. I too never encountered before. Yes, I do review the ODB++ file with its free viewer and there it shows correctly as displayed in PCB or Artwork file. Even the Placed Component report also shows the correct location. I'm confused.
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    I would recommend asking the assembly house to verify that CAD CAM Professional is reading the ODB++ data correctly,
    I just verified that the components on the bottom layer are written to the <jobname>/steps/stp/layers/comp_++bot/components file...
