  3. Length match in DDR3 FLYBY (need som like virtual pin?)
  • Views 15250
Leotordo
Leotordo over 6 years ago
 I'm relative new in Orcad and I'm working on a board with two DDR3 RAM.
Address lines have flyby termination, so I've to route traces from CPU ball to first RAM then to second one and at last to the resistor.
Here you are a hand made diagram with two lines routed
At the moment address lines are in one Match Group but this is not the right rule. I need to setup a rule like this
  • match addresses net from CPU to RAM1 (blu lines in my diagram)
  • match addresses net from RAM1 to RAM2 (red lines in my diagram)
  • net from RAM2 to resistor doesn't care
In Mentor programs there's Virual Pin objet for this rules but in Cadence I'm not skilled
Can anybody help me?
Thank you
Stefano
  • avant
    avant over 6 years ago
    You can set up pin pairs in the min/max delay section.
    You need to enter time or length values before exiting or the pin pairs will be lost.
  • Leotordo
    Leotordo over 6 years ago in reply to avant
    tomorrow I'll try, my working day is ended
    thank you
    Stefano
