  3. Drill table Creation in allegro 17.2
  • Subscribers 166
  • Views 22348
jayukacha
jayukacha over 6 years ago
I am having a problem with creating a drill table in allegro 17.2. To create a drill table and put in the artwork area i have done as below.
Manufacture > Create Drill Table > Pressed Ok(changed nothing in this pop up)
Then I have a drill table shown in the artwork are and I have also put it into the artwork area. but after changing the view from the visibility panel, the drill table disappears.
Help me with the same.
  • UlfK
    UlfK over 6 years ago +1
    My experience with drill tables are that if they are defined for separate layers, these new sub-classes gets created at time of instantiation and they might not be visible. They also gets created with…
  • Wild
    Wild over 6 years ago in reply to UlfK +1
    FYI - Many of the folks I've worked did not realize the drill tables are created as a group, so to move one your must have the group option selected under filters. Good luck Wild.
  • redwire
    redwire over 6 years ago +1
    As the others have said, it appears on a new manufacturing layer. Be sure to add that layer into your view or it will "disappear" because its visibility changes.
  • Dale Peterson
    Dale Peterson over 6 years ago in reply to Wild
    Hmm, for me all i do to move the drill chart is this--- Just make sure you have "shapes" turned on in your find filter. Then just pick the outline of the drill chart and move it to a your new location. Next-- re-run "Create Drill Table" under the "Manufacturing" tab.  The table will be refreshed good as new in your new location. ---just another way of doing this.
