  3. Reports of Cline segment.
  • Views 16354
vimaldevlpr
vimaldevlpr over 6 years ago
Hai,
I would like to take cline segments report (Net name, xy, (Vertical, horizontal or angled)) is there a way to take if it possible means can anyone please guide me or share me the skill code please.
vimal
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    The skill code below is an example of saving the 'show element' output to a file:
    procedure((report_clines \@optional FileName)
    prog((oldVisData oldSetData OutputName Result)
    if( FileName then
    (OutputName = strcat(simplifyFilename(".") "/" FileName))
    (OutputName = FileName)
    else
    (OutputName = strcat(simplifyFilename(".") "/clines.txt"))
    if(isFile(OutputName) then
    unless(deleteFile(OutputName)
    (axlMsgPut "ERROR: could not remove existing file %s" OutputName)
    return()
    (axlClearSelSet)
    (oldVisData = (axlVisibleGet))
    (axlVisibleDesign t)
    (axlSetFindFilter
    ?enabled list("noall" "clinesegs" "invisible")
    ?onButtons list("noall" "clinesegs")
    (axlAddSelectAll)
    (Result = axlShowObjectToFile( (axlGetSelSet) OutputName))
    (axlVisibleSet oldVisData)
    if( listp(Result) && equal( length(Result) 3 ) then
    axlMsgPut("%d lines written to %s" caddr(Result) car(Result))
    else
    axlMsgPut("report_clines failed!")
    axlFlushDisplay()
    axlUIWUpdate(nil)
    (axlShell "redraw")
  • vimaldevlpr
    vimaldevlpr over 6 years ago in reply to DavidJHutchins
    Hai david
    Kindly Thanks for your support but i have an one more suggestion please.
    My reports like..
    Net name                 segment                                          xy location                  xy location
    GND                        HORIZONTAL LINE SEGMENT      (448.41 2925.69)        (402.20 2925.69)
    N16894896              ODD-ANGLE LINE SEGMENT        (403.30 2888.70)        (405.69 2886.31)
    Can you please change like this method please..
