  3. Allegro -> Design Workflow - workspace - custom-menu ->...
  • Views 3210
Allegro -> Design Workflow - workspace - custom-menu -> system command
rs ms aricent
rs ms aricent over 6 years ago
currently looking at creating new workflow items in custom workspace
would like to be able to call out windows system variables and or allegro enviroment variables with the "system" command in conjunction
help desc
system
The system command executes the operating-system command you have specified. The system command supports the redirection and wildcard notation of the host operating system.
Syntax
system <OS command>
Example
system mv abc.brd /home/usr/brddir
currently I have to use a .BAT file to do that
<task name="edit env" command="system 'notepad %HOME%\pcbenv\env'"></task>
<task name="test env .bat" command="system 'C:\tmp\test_env.bat'"></task>
bat file example
notepad %HOME%/pcbenv/env
once I figure it out,  there are many things that could be put in the design workflow - workspace  menu
if you have other wrapper cgywin, etc. please post.
note:  looks like a lot easier to change workspaces - menus ,  then edit custom skill code driven menu system :-)
appreciate any tips/tricks/examples      :-)  Robert
  • EvanShultz
    EvanShultz over 6 years ago
    axlGetVariable() and axlGetVariableList() will get Allegro and system variables. Does that help?
    I would also like to call the OS shell, for example to run PowerShell commands, from within Allegro but I don't know how to do it. Any tips?
  • DavidJHutchins
    DavidJHutchins over 6 years ago in reply to EvanShultz
    I have been using the skill system() call to run compression programs on specific output files for years, can you try something like:
    Command >  skill system("powershell")
