  3. 3d-model component
  • Subscribers 166
  • Views 15623
3d-model component
Neco66
Neco66 over 6 years ago
Hello everybody, have a lot of components (about 3000), which are without 3D models. How can I highlight the components without 3D models? Is there a way to output a list, in which the components are listed with the associated 3D models?
Is it possible to add .x_t or .x_b documents as 3D to the components?
Many thanks in advance.
  • RFinley
    RFinley over 6 years ago
    I suspect you would run Extracta against each psm output (of the dra file) to find the step mapping properties.   Has anyone found documentation on using Extracta?
    The only safe method I have found against missing models is >Setup >Step Package Mapping and check the box halfway down "Symbols missing Step models".  They don't have a report you can run for some reason.  O_o
  • steve
    steve over 6 years ago in reply to RFinley
    Try the Report button on the Setup >Step Package Mapping form which will list all the details for parts with and without models mapped.
  • Micheal schenk
    Micheal schenk over 6 years ago
    You can also use the below option
    Goto 3D view - Setup - Preferences - Symbol representation. You can choose "Only Boundary shape" which displays symbols without step and "Only Step" displays symbols with step models.
    Selecting a component highlights the symbol on board.
  • cdlep
    cdlep over 6 years ago in reply to RFinley
    I usually use SKILL to pull data these days but here are two documents you need to be familiar with for the extracta command:
    c:\Cadence\SPB_17.4\doc\algrodescmp\chap5.html
    c:\Cadence\SPB_17.4\doc\algrodescmp\appa.html
    Should be in 17.2 also BTW
