  3. gerber out setup
  • Views 15869
gerber out setup
masamasa
masamasa over 6 years ago
hello
is there a way to set up the decimal places as a default for exporting the gerber out?
the decimal places in the artwork control form is set up as 5 but i would like to change it to 4 as a default.
  • steve
    steve over 6 years ago
    Set this up once then in the board directory is a file called arm_param.txt. This stores what you set. Move or copy this file to a network location say drive:\Cadence\setups then in Allegro go to Setup>User Preferences>Paths>Config and set the artpath to point to the directory you created. It should be used going forward
  • masamasa
    masamasa over 6 years ago in reply to steve
    thank you, steve.
    i was able to set the default value.
    after the decimal places get changed to 4, i always get this message.
    is there a way to stop this message to show up?
  • redwire
    redwire over 6 years ago in reply to masamasa
    Yes, but you need to reduce your board resolution at the same time as the message says.
  • masamasa
    masamasa over 6 years ago in reply to redwire
    thank you for your response, redwire.
    my design has 2-decimal-place accuracy as shown below.
    according to the warning message, i need to set the decimal places one greater than the detabase acccuracy.
    for the gerber out, i set the default decimal places as 4, which is two greater than the databse accuracy.
    but i am still getting the warning message.
    am i reading the warning meesage correctly?
