  3. How ToMake A Custom Pastemask Shape ?
  • Replies 13
  • Subscribers 168
  • Views 23992
nutron
nutron over 6 years ago
I would like to make a footprint of this IC.
I got the shape of the thermal pad done , but as shown in the attached picture , the paste mask is not equally shaped like the thermal pad.
How does one create the suggested paste mask so it matches the shape of the thermal pad ?
I tried to create a flash , but the problem is that i can not see where i need to place the segments of the paste mask .
Do i need to create the footprint of the IC and then add the paste mask in PCB designer to the footprint instead of doing it in the PAD EDITOR ?
  • nutron
    nutron over 6 years ago in reply to redwire +1
    I ended up doing what you suggested. i just created the thermal pad shape in PAD EDITOR and then added the paste mask in PCB DESIGNER to the package drawing. I wasn't sure if that is the 100% kosher way…
  • Jason Hsu
    Jason Hsu over 6 years ago in reply to nutron +1
    Just like this? Yellow is shape on PASTEMASK_TOP, Green is shape on SOLDERMASK_TOP. I use skill code to generate it.
  • nutron
    nutron over 6 years ago in reply to Wild
    Isn't this the job of the electronics design software ?  Somehow this defeats the purpose of ORCAD if one needs to use CAD software to create pad shapes.
  • Wild
    Wild over 6 years ago in reply to nutron
    I did not say that you could not do this in Allegro, nor did I imply this. i just mention how I do it now as an FYI..  It's just easier to create complex shapes in an MCAD tool.   Back in the day I used to create these types of shapes in in much earlier releases of Allegro.  Since my company has the MCAD tools I take advantage of these.  So if you don't have access to such tools, then create the shape symbols as previously mentioned.
    Have fun.
    Wild
  • nutron
    how i did it...
    1. created the pad shape in PCB designer and saved it.
    2. expanded the shape and saved it as pad solder mask.
    3. in PAD editor i used the pad shape as pad shape and the pad solder mask as solder mask shape.
    4. I drew the shape of the paste mask in PCB designer during the creation of the package drawing.
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/27/2045.vson_5F00_10_5F00_ep.zip
