  3. commands that was performed by GUI
  • Views 15571
dontknowwhy
dontknowwhy over 6 years ago
hello there, i'm a student studying allegro PCB designer.
There are some commands that i can do with GUI, but i want to know what kind of commands i used so that i can route with commands only(ex) skill).
Is there any file that i can see what kind of commands i used something like log files or command history?
thank you for reading this long boring question.
  • B Bruekers
    B Bruekers over 6 years ago +1
    Use this in the Allegro commandline: 'scriptmode +e' This will echo the exact commands which you use eg. during routing. Also changes on a form are shown. To unset use '-e' If you want to save all…
  • B Bruekers
    To unset use '-e'
    If you want to save all form fields at once: open the form (eg drill legend)  and press  ctrl+p. This will show a popup where you can save a script file.
    Bram
  • dontknowwhy
    dontknowwhy over 6 years ago in reply to B Bruekers
    it is exactly what i wanna see...... thank you for reply :)
