  3. constraint manager setup question
  • Views 15336
masamasa
masamasa over 6 years ago
hello
i would like to set up the constraints for diff pairs.
for clines in general, the space is 100um.
the space between clines of a diff pair is 50um.
is there a way to set up a gap between a cline of one of the diff pair and a cline of a different net which is GND?
I would like to set up the gap as 150um.
i have created two spacing sets, one for 100um in general and the other is for diff pairs, 50um.
do i need to create another set for 150um?
i do not know how to set up the constraints for diff pair nets and GND.
  • steve
    steve over 6 years ago
    Read this:- orcad.co.uk/.../diffpairs_definition.pdf page 6 onwards describes how to setup space between diff pairs and other nets
  • masamasa
    masamasa over 6 years ago in reply to steve
    thank you, steve
    i will read the documant.
    you always help me a lot.
    i appreciate it.
  • markt757
    markt757 over 6 years ago in reply to masamasa
    Same here. Thanks Steve, you're posts have helped me many times, and in fact, helped me out yesterday/today when I was trying to figure out why some of TE's dxf's were coming in 2, 4, or 5 times larger than what I needed. You're manf, drafting, create detail, set scaling factor worked perfectly!
