  3. Updating/replacing/creating new film records
  • Views 3224
EvanShultz
EvanShultz over 6 years ago
We have many legacy board designs which have non-standard films. I'm writing SKILL code to automatically align a board's film records with our internal standard.
While I'm sure there will be multiple questions, here are the first two I've run into:
1. It seems the polyCutLayer parameter of axlFilmCreate() doesn't work. You can easily see this for yourself. Try typing "axlFilmCreate("test" ?polyCutLayer nil)" on the command window in Allegro. I'm returned "nil", indicating the film could not be created, and I see "*WARNING* (axlFilmCreate): Invalid option type: ?polyCutLayer" in the command window. Just to try a different parameter and see that it works, try "axlFilmCreate("test" ?negative t)". I'm returned a "t" and the film is created. Page 139 of 17.4-2019 algroskill.pdf shows this parameter and I can see it listed if I inspect an existing from from the DB, so what gives? Is the polyCutLayer parameter broken when creating films?
2. In conjunction with the above, if I loop through all current films and use axlDeleteObject() to remove them all, and then try to create new films but give an argument to the polyCutLayer parameter, films containing copper layers seem to be automatically created. There are four films (my test board has four layers) with the ETCH/, PIN/, and VIA CLASS/ subclasses. I am able to manually delete all films and see absolutely no films at all. Is there something weird going on here or is this to be expected for some reason?
I'm running Allegro 17.4s002.
  • EvanShultz
    Nope. Got confused. I can't delete all films manually (I did see a totally blank window once, somehow). Tried again and the last film cannot be deleted in the UI. So I guess re-creating all copper film automatically is the solution for the using deleting all films via SKILL?
  • EvanShultz
    1. Cadence got back to me that the polyCutLayer parameter is no longer supported and it will be removed from the documentation. So that is closed.
    2. I figured this out in my reply below.
