  3. How to disable *.log files creation
  • Views 17174
nutron
nutron over 6 years ago
Is there a way to disable Allegro / PCB designer to constantly create log files for every little thing one does?
I noticed that whenever i modify something about a footprint or do other activities , Allegro / PCB designer creates log files.
I keep manually removing them to reduce clutter , but i was wondering if loging could be disabled.
  • DavidJHutchins
    DavidJHutchins over 6 years ago +1
    try adding the following setting to your %home%/pcbenv/env file to write the log files into a folder other than the design folder: set ads_sdlog = c:/temp
  • DavidJHutchins
  • nutron
    nutron over 6 years ago in reply to DavidJHutchins
    Do you know if this makes Allegro write all *.log files to that folder , or only the ones generated during the footprint creation and edits ?
  • DavidJHutchins
    All log files...
    How would it know the difference between editing a drawing for a footprint vs a board symbol, they both have a .dra suffix ???
