  3. Using Numeric Keypad keys as funckeys
  • Views 16922
Jacek Renkas
Jacek Renkas over 6 years ago
I want to assign functions to numeric keypad keys.
For example I would like to have "Ctrl+numpad4" create fanout with direction west. "Ctrl+numpad6" fanout with direction east. And so on.
My problem is that I don't know how to name the kaypad keys in the env file?
When I want to assign something to Ctrl+numpad4 how should I write this?
And I want to use this with NumLock enabled so that numeric input works.
  • masamasa
    masamasa over 6 years ago
    funckey ~4 "create fanout;FORM mini crfan_via_direction West"
    funckey ~6 "create fanout;FORM mini crfan_via_direction East"
    please make sure before hitting Ctrl+4 and Ctrl+6, the numlock is on.
  • Jacek Renkas
    Jacek Renkas over 6 years ago in reply to masamasa
    Unfortunately it doesn't work for me. It works with the standard 4 but hitting numpad 4 does not have any effect...
  • mcatramb91
    mcatramb91 over 6 years ago in reply to Jacek Renkas
    A couple of things.
    • Disable "enable_command_window_history" in your Allegro environment.  When set the Control+Number Pad Key does not seem to work, at least for me :-)
    • I have seen different Control key settings for the Number pad depending on the keyboard/computer.  The easiest thing to do is enter a space on the command line than select the Control+Number Pad Key to see what prints out.  For example, my number pad Control+4 comes out as ~d and my number pad Control+6 comes out as ~f
    I believe the key here is disabling the command history window as it prevents function key settings for the Number Pad Keys.
    Give it a try.
    Hope this helps,
    Mike Catrambone
  • masamasa
    masamasa over 6 years ago in reply to mcatramb91
    i am sorry, i typed wrong.
    and mike is correct
    please try the followings:
    funckey ~d "create fanout;FORM mini crfan_via_direction West"
    funckey ~f "create fanout;FORM mini crfan_via_direction East"
    numpads Ctrl+1 thru Ctrl+9 are corresponded to ~a thru ~i.
