  3. Unable to find unrouted net
  • Subscribers 166
  • Views 16575
jatins
jatins over 6 years ago
Hi
There is only one unrouted net remaining in my design. and i am unable to find it.
I tried setting global visibility to off and then displaying rats all.
It did not help. I do not know maybe it is some via which is unconnected to trace. How can i find it out?
  • Dale Peterson
    Dale Peterson over 6 years ago
    Zoom in on the board then clicked on the coordinate of the "unrouted connection" found in the status report.It will take you right to it. If you still can't figure it out. Just delete and re-attach parts or all of the net not routed to make the unrouted go away.
    Cheers
  • masamasa
    masamasa over 6 years ago
    i have experienced this many times.
    the "unconnected pins report" says there are some unconncected nets but the show-rats-lines do not show where they are.
    what i usually do is to find antenna vias by the "dangling line, via and antenna report" and remove or modify those antenna vias.
