  3. Why do vias change net name ?
  • Views 15558
Lennie
Lennie over 6 years ago
When I  change a plane on another layer certain vias that are not related change there net name. Is there any way to stop the software from changing the net names on vias ?
  • masamasa
    masamasa over 6 years ago
    if the vias are not connected to anything but only to the plane that you are changing, the vias are automatically changed to the net name of the plane.
    but if you set the "retain_net on_vias" as "true" on the properties of the vias, you can keep the orignal net name to the vias.
  • steve
    steve over 6 years ago in reply to masamasa
    You can also set this in Constraint Manager - Properties - Net - General Net Properties. there is a retain net on vas column.
  • Lennie
    Lennie over 6 years ago in reply to steve
    Great. Thanks . Appreciate your help.
