  3. Changing properties on a dynamic shape.
  • Views 16670
Lennie
Lennie over 6 years ago
On dynamic shapes you can edit properties but the software does not same them. Is there a way to make this work ?
  • steve
    steve over 6 years ago
    This is working for me so make sure you are using the latest version of whatever version you are running. 17.2-2016 S064 or 17.4-2019 S003 both available from support.cadence.com or Download Manager
  • Lennie
    Lennie over 6 years ago in reply to steve
    I am on s064. I select a dynamic shape/ property edit select pins allowed , change to blank, apply, close screen then reselect shape and property edit and there is no properties set on the right side. Can you duplicate this and see the property set ?
  • steve
    steve over 6 years ago in reply to Lennie
    Yes because this property is ONLY allowed on a Route Keepout shape. if I try and add this to a copper shape I get an error at the command line....
  • Lennie
    Ok thanks. The software should remove those that cannot be set instead of telling you to set it to blank and then have an error in the command line. I missed the command line response.
