  3. Shorts and DRC
  • Replies 8
  • Subscribers 167
  • Views 19845
Shorts and DRC
4ricktan
4ricktan over 6 years ago
How do I make a 2 pin component who's sole function is to short pin1 and pin2 together without DRCs?
I would like to make the overall outline to be small enough to fit in between the 2 pads of a 0201 resistor/capacitor.
  • cdlep
    cdlep over 6 years ago +1
    Here is a solution that fits pretty much anywhere: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000007MqM1UAK&pageName=ArticleContent
  • cdlep
    cdlep over 6 years ago in reply to Wild
    I did not know you were using Capture!  Slight smile   The documentation specifies DEHDL but you may want to file a case and ask Cadence about doing this in Capture or just give it a try.  I use it a lot for far end star single source clocks in addition to sense lines.
  • Wild
    Wild over 6 years ago in reply to cdlep
    Not sure what the original poster uses, but my team is in the capture land.  I've used the netshorting trick for a number of years (too many), only issue I've had is that the cam file check at fab shows an unconnected net between the netshorts.  Scream  I usually just approve and move on, this scheme looks like it is a better solution.  I may enter a ticket on this one.  Many thanks!
  • cdlep
    I believe it usually shows as two or multiple nets shorted.  I drive a lot of things grammatically and in my environment the user ends up with  a standard note to add to the fab drawing detailing each use of the forcesense symbol detailing location and nets shorted.   One of either ODB++ or 2581 also tags it nicely as a net short instance.  I forget which at the moment.
