  3. RatsNest Control in Allegro how to make it more usable ...
  • Replies 13
  • Views 30343
RatsNest Control in Allegro how to make it more usable ?
excellon1
excellon1 over 6 years ago
Hi all.
In Allegro/Orcad does anyone know if some skill code exists that would make enabling/disabling ratsnest guides/lines more dynamic ?
In the Specctra route editor I find it far easier to use to enable disable nets than in Allegro.
For example in Specctra you can simply click a pin or window select a component and the rats show up. If you window select a component or pin again that is showing the ratsnest then the ratsnest turns off.
This works great and has been that way for years in Specctra.
Over on the Allegro side of things you have to do two operations basically enable, disable. For example "Show Rats Net" & "Blank Rats Nets"
The dual operation is really tiresome, too many clicks IMHO.
Ideally what I am after is basically a toggle for the ratsnest. Click the pin and the rat appears, click the pin again and it disappears.
It is doable with hot keys but I have too many already assigned Slight smile
Thanks.
  • excellon1
    excellon1 over 6 years ago in reply to AvengerThanos
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/27/3122.Rats.zip
    Hi AT
    So you can use strokes to do lots of things and as you can see above they can be handy. So the thing is how to :), Well it's not to bad to configure things but first some background info.
    On my system here I use a 3 Button Mouse and i'm sure most people are doing that too.
    So by default allegro comes with a default strokes file. The strokes file resides in the pcbenv folder and it has a .strokes extension, Mine is called allegro.strokes. Typically that allegro strokes file is loaded by default when you start allegro.
    The default strokes file comes with some pre-defined strokes. To see what they are "Im using 16.6" should be similar in 17x too. Go to > tools > utilities > Stroke Editor to launch the stroke editor. What you will see is basically a graphical representation for a command and that's the idea. In other words you would draw a stroke on the allegro canvas to execute a command associated with that stroke.
    To invoke a stroke in allegro by default you have to hold down the control key and then use the right mouse button to draw the stroke on the screen. To try things out hold down the ctrl key and draw a Z with the right mouse button. The display should zoom in for you.
    Now the action of holding down the control key can be changed so you don't have to do that to invoke a stroke. This will make things alot easier IMHO. Go to User Preferences then go to UI > Input and check the box "No_dragpopup". Exit out of the preferences editor.
    Try that "Z" stroke again. Just draw a z on the canvas with the right mouse button and the display should zoom in. The trick is to dry draw your stroke to be as close as possible to what the stroke looks like. Play around after some practice you will get the idea.
    The stroke editor is not really intuitive so play around to get the idea of how it works. Before making changes to the existing allegro.strokes file a good idea is to copy it to a usb drive or something so you have a backup.
    In the stroke editor you can also load other stroke files which is handy. Load my stroke file called rats.strokes in the stroke editor after unzipping the attachment "Use file open to do that" - File attached. Have a look at the strokes that I defined for the rats operation. Basically a L and a L drawn to the left. Save that rats.strokes file to you pcbenv directory. The reason for this is that allegro has to know where to look for the file.
    Ok lastly try things out.
    In allegro first load the rats.strokes file. In the allegro pcb editor command window type     strokefile rats.strokes    - Note the command syntax is   strokefile and then the strokefiles name.
    Next try out the strokes on a board. A good test is to see how it works on a unratted board. You can turn off all rats first so as to remove the clutter then use the strokes to turn on or off at will.
    Have fun...
  • Dennisco
    Dennisco over 6 years ago in reply to excellon1
    I  like to type for most of my commands so I  create script files and use "alias"  for "Ratsnest by Signal name" (back in 2012 still using the script on V17.2)
    In your ENV file:
    alias rn "replay rn"        # ratsnest by signal name Note: replay = using a script in the script directory
    alias br unrats net           #  Blank Rats net
    Here is the Script file for "rn"   probably out dated and sloppy but at the time it was quick and easy and it still works and it is fast.
    # Allegro script
    # start time: Mon Oct 29 10:22:19 2012
    # Version: 16.5 S020 (v16-5-13AY) i86
    version 16.5
    setwindow pcb
    trapsize 1935
    generaledit
    rats net
    # stop time: Mon Oct 29 10:22:36 2012
    other simple alias that I created either using scripts or commands that are in my ENV file, (to get your creative juices going)
    alias hn "replay hlightnet"       # highlight net
    alias dhn "replay dhlightnet"     # de-hilight net
    alias ra rats all             # ratsnest all signals
    alias ur unrats all           # unrats nest all
    alias rc "replay ratcomp"     # ratsnest component
    alias urc "replay unratcomp"  # un-ratsnest component
  • AvengerThanos
    AvengerThanos over 6 years ago in reply to excellon1
    Hi Excellon,
    I performed as you suggested but the issue is I am unable to write a stroke on PCB canvas. I used ctrl + RMB yet I get a window select view, not a stroke as seen in your video. Is there any setting or application mode to enabled. I am using 17.2 S064
  • excellon1
    Hi AT
    Well you don't have to use the ctrl+rmb to do anything. If you look at my previous post I mention an option to disable it using a preference. I tested this using 16.6 but will circle back later to see if it does indeed work on 17.2 SO64
    Here is that previous setting item.
    By what you write it sounds like the actual stroke is not getting drawn on the canvas and it should. Will circle back in a bit.
    We can fix Slight smile
  • excellon1
    excellon1 over 6 years ago in reply to excellon1
    HI AT
    Checking 17.2 s064 everything is working at this end. Maybe try the following in order and see if it works.
    1 Go to User Preferences then go to UI > Input and check the box "No_dragpopup". Exit out of the preferences editor and close out allegro.
    2 Extract rats.zip which contains rats.strokes to your pcbenv folder. On my system the path is c:\spb_data\pcbenv.
    3 Go to the pcbenv folder and make sure rats.strokes file exists there.
    4 Go into Allegro
    5 Load the rats.strokes file in the command window using this command      strokefile rats.strokes    If the file is not found or there is a problem info will be displayed in the command window..
    Load a board and enable all the nets so they show.
    Last part is using the actual stroke. Hold down your right mouse button "Keep it held down" and draw a reversed L like in the small video above. Release the right mouse button and click or window select the nets. They should turn off. Doing the same again this time draw an L, release the right mouse button. Window select or click the pins of the part the nets should turn on.
    When drawing a stroke you have to keep the right mouse button held down. Its like draw and release. The stroke should appear in white on your canvas. If the system does not understand your stroke info will be displayed in the command window. It takes a little while to get used to drawing with the right mouse button held down.
    BTW the stroke will default to generaledit mode. So if you were in etchedit mode and drew the stroke it will put your system in generaledit mode. The actual mode can be changed in the stroke file if needed.
    Everything works here. Hope you get it to work. Let us know.
