  3. RatsNest Control in Allegro how to make it more usable ...
  • Replies 13
  • Views 30348
RatsNest Control in Allegro how to make it more usable ?
excellon1
excellon1 over 6 years ago
Hi all.
In Allegro/Orcad does anyone know if some skill code exists that would make enabling/disabling ratsnest guides/lines more dynamic ?
In the Specctra route editor I find it far easier to use to enable disable nets than in Allegro.
For example in Specctra you can simply click a pin or window select a component and the rats show up. If you window select a component or pin again that is showing the ratsnest then the ratsnest turns off.
This works great and has been that way for years in Specctra.
Over on the Allegro side of things you have to do two operations basically enable, disable. For example "Show Rats Net" & "Blank Rats Nets"
The dual operation is really tiresome, too many clicks IMHO.
Ideally what I am after is basically a toggle for the ratsnest. Click the pin and the rat appears, click the pin again and it disappears.
It is doable with hot keys but I have too many already assigned Slight smile
Thanks.
  • AvengerThanos
    AvengerThanos over 6 years ago in reply to excellon1
    HeyExcellon,
    I tried with the steps you mentioned but I am unable to get the stroke option with ctrl key. Is there any specific application mode to be enabled.
  • excellon1
    excellon1 over 6 years ago in reply to AvengerThanos
    Hey AT
    The thing just works as I described above. A couple of questions:
    Are your left and right mouse buttons swapped ?
    When you load the rats.strokes file do you get any errors shown in the command window ?
    BTW: "You don't need to be holding down the ctrl key to invoke strokes if you changed your user preferences as I indicated above.
    It is bizarre it is not working for you :) , I tried it on 16.6 and latest cut of 17x with zero issues here.
    Best of luck, if you cant get it to work then something is wrong with your install or some setting is breaking the action of using strokes.
    Maybe call Cadence support to see what they think.
    All the best.
  • AvengerThanos
    Hi excellon,
    I got it working. Thnks
