  3. Editting a DFF .csv file issue
  • Replies 8
  • Views 19453
Casey O
Casey O over 6 years ago
I'm trying to edit a Design True DFM  .csv file and by doing so break the .csv into multiple files for review and adoption in my team at Intel. What I want to do (and did) was to "shorten" the default DFF csv file into smaller segments. After doing so paying careful attention to the headers and beginning an end of the different sections of the csv file I could load it into a allegro .brd file but no new drc's for DFM showed up. I looked at the log file no apparent issue. I used excel to edit the .csv and save it as a .csv file before reading it into a board file. Any help would be greatly appreciated. This is a Allegro 17.2 database 17.2-2016 S062 [11/25/2019] Windows SPB 64-bit Edition
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    Casey,
    I did some work attempting to make a set of these files that were more realistic vs the 'conservative' values that were used to build these files,
    contact me directly at mtnhomecadservices@gmail.com to discuss this further ( I'm idle right now waiting for lab debug feedback... )
  • DavidJHutchins
    DavidJHutchins over 6 years ago in reply to DavidJHutchins
    Casey,
    I took the most recent Intel design I worked on & loaded it into 17.4, imported the Cadence default DFF file & got 40479 errors detected.
    I closed that session, reopened it & loaded my modified DFF file & got 4937 errors detected. Most of these are ViaInPad 'overlap' violations & min line width since some of the diff-pairs had 3.3 mil line width;
    I closed that session, modified the DFF file to change the min width from 3.5 to 3.3, reopened it & loaded my modified DFF file & got 3007 errors detected.
  • DavidJHutchins
    Casey,
    It might help getting a set of these rules file from a board fabrication house as a more realistic set of files to start from, try submitting a request using https://pcb.cadence.com/dfm_customer#
