  3. How to set shortcut key to cycle through predefined trace...
  • Replies 8
  • Views 22003
How to set shortcut key to cycle through predefined trace width settings
Dutch2
Dutch2 over 6 years ago
I'd like to assign a shortcut key to select a trace width from a predefined list while routing.
For example, I'd like to select between 0.082mm, 0.127mm, and 0.254mm.
Any suggestions on how to do this, or where to find more information on how to do it would be greatly appreciated!
P.
  • DavidJHutchins
    DavidJHutchins over 6 years ago +1
    try the following command: funckey w "settoggle width '0.082' '0.127' '0.254' ; FORM mini acon_line_width $width" Then when routing use the 'w' key to toggle thru the width values
  • DavidJHutchins
  • Dutch2
    Dutch2 over 6 years ago in reply to DavidJHutchins
    Thanks for your reply.
    I added the command, then selected Add connect and selected a pin.
    pressing the 'w' key just shows up in the Command window and does not toggle the line width?
    I'm sure I'm missing something obvious here.
    Command > funckey w "settoggle width '0.082' '0.127' '0.254' ; FORM mini acon_line_width $width"
    Pick first element.
    last pick: -26.5938 22.9616
    last pick: -26.5962 22.9502
    Target Symbol Pin is defined on BOTTOM.
    Command > w
    E- Command not found: w
    Command >
  • DavidJHutchins
    I originally did this is 16.6, so I switched to 17.2 & it works for me without any issues, below is the journal file entries:
    \i (00:01:21) funckey w 'settoggle width `'0.082`' `'0.127`' `'0.254`' ; FORM mini acon_line_width $width'
    \i (00:01:26) add connect
    \t (00:01:27) Pick first element.
    \i (00:01:33) pick grid 75.2709 73.4239
    \t (00:01:33) last pick: 75.2729 73.4187
    \t (00:01:33) last pick: 75.2856 73.4060
    \i (00:01:40) pick grid 75.3015 72.7620
    \t (00:01:40) last pick: 75.2983 72.7583
    \t (00:01:41) No DRC errors detected.
    \t (00:01:41) last pick: 75.2856 72.7710
    \i (00:01:44) settoggle width 0.082 0.127 0.254
    \i (00:01:44) FORM mini acon_line_width 0.082
    \i (00:01:44) setwindow form.mini
    \i (00:01:44) setwindow pcb
    \i (00:01:44) trapsize 306
    \i (00:01:53) pick grid 75.5589 72.2411
    \t (00:01:53) last pick: 75.5650 72.2376
    \t (00:01:53) No DRC errors detected.
    \i (00:01:54) settoggle width 0.082 0.127 0.254
    \i (00:01:54) FORM mini acon_line_width 0.127
    \i (00:01:54) setwindow form.mini
    \i (00:01:54) setwindow pcb
    \i (00:01:54) trapsize 306
    \i (00:01:55) pick grid 75.9695 71.8550
    \t (00:01:55) last pick: 75.9714 71.8566
    \t (00:01:55) No DRC errors detected.
    \t (00:01:55) last pick: 75.9587 71.8439
    \i (00:01:56) settoggle width 0.082 0.127 0.254
    \i (00:01:56) FORM mini acon_line_width 0.254
    \i (00:01:56) setwindow form.mini
    \i (00:01:56) setwindow pcb
    \i (00:01:56) trapsize 306
    \i (00:01:57) pick grid 76.6130 71.8795
    \t (00:01:57) last pick: 76.6191 71.8820
    \t (00:01:57) No DRC errors detected.
    \t (00:01:57) last pick: 76.5810 71.8439
    \i (00:01:59) pick grid 76.8827 72.1614
    \t (00:01:59) last pick: 76.8858 72.1614
    \t (00:01:59) No DRC errors detected.
    \i (00:01:59) prepopup 76.9011 72.5414
    \i (00:02:00) done
  • Dale Peterson
    Dale Peterson over 6 years ago
    Dutch,--- Just use this to assign your keys "funckey q FORM mini acon_line_width .2" The q is the key assignment and .2 is the routing width in mm. So just change both of these to meet your needs. Also clone it and assign other keys and widths.
    All of my widths are assigned of the QWERTY keys. Which makes it easy for me to rip through widths before routing something.
    cheers
  • Dutch2
    Dutch2 over 6 years ago in reply to Dale Peterson
    Hi Dale,
    That works just fine. (I used key 1..4) It's the toggle that I can't get to work.
    Thanks.
