  3. How could I export a list of reference designators in a...
  • Views 16805
How could I export a list of reference designators in a board area?
MarcG58
MarcG58 over 6 years ago
I'm a Producibility Engineer who gets to review new PC designs during the design phase, looking for areas that might prove "challenging" to manufacture. We've got a new design that has several challenging areas and are looking to produce a test board to work on our processes in those areas. I need to create a BOM from the brd file for just the parts we're interested in.
Ideally I would be able to select that area and then execute some kind of report generator to output the ref des of the selected parts. Is there a way to come close to that?
Thanks.
  • RFinley
    RFinley over 6 years ago
    The straightforward method is to..
    Set your Find filter to Symbols only.
    Select the parts/area you are interested in.
    >menu button(right) >Show Elements
    A new window will pop up with a very verbose report.  Fortunately, you can save it as a dot txt file, slurp it into Excel, one line per cell.  Sort by Cell.
    Delete all lines that don't start with RefDes.  Save.  Done.
    As a side note, we use Capture CIS as our front end.   Show Elements reports the PART_NUMBER property for each part, indexed to our CIS database to extract the MPN.
    To preserve the line sequence, insert a column in excel and add a line number.   When you delete everything but the Refdes, Room, and Part_Number property, you have that static line number property that you can sort to to recover the sequence that indicates which properties go for that refdes.
  • MarcG58
    MarcG58 over 6 years ago in reply to RFinley
    That will definitely work for me. Thanks!
