  3. How to output all textblock used in board file
  • Replies 7
  • Views 17894
eric22
eric22 over 6 years ago
Hi All,
Is there any script available in order to make report for all the text blocks used in one design?
I want to standardize the text block for very design, before that I want to make some list what are the textblocks used and which class/subclass.
Thanks.
Eric
  • eric22
    eric22 over 6 years ago in reply to DavidJHutchins
    Hi David,
    Thanks so much for your time in helping me out.
    I tried your inputs and I got some error.
    Can you please spare some time what I need to do in the code to avoid this error?
    Command > skill '(load "tb.ils")'
    E-
    E- (00:00:21) skill '(load "tb.ils")'
    E-                                  ^
    E- SYNTAX ERROR found at line 1 column 34 of file tb.ils
    W- *WARNING* (reader): suspicious newline found after the operator '
    E- *Error* lineread/read: syntax error encountered in input
    E- *Error* load: error while loading file - "tb.ils" at line 1
    ERROR
    E-
    E-                                  ^
    ERROR
    Command >
    Best regards,
    Eric
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    Based upon the error I think you may have used a word processor ( i.e. wordpad ) instead of a text editor ( i.e. notepad ) to create the file
    Can you launch a Windows 'Command Prompt' session & issue the following commands shown in bold:
    C:\temp>type tb.ils
    procedure(report_tb()
    let((l_textblocks line)
    (l_textblocks = list())
    foreach(symdef ((axlDBGetDesign)->symdefs)
    foreach(child (symdef->children)
    if((child->objType = ("text" && (child->textBlock))) then
    (line = strcat((child->layer) " " (child->textBlock)))
    unless(member(line l_textblocks)
    (l_textblocks = cons(line l_textblocks))
    foreach(text ((axlDBGetDesign)->text)
    if((text->objType = ("text" && (text->textBlock))) then
    (line = strcat((text->layer) " " (text->textBlock)))
    foreach(tb sort(l_textblocks 'axlStrcmpAlpNum)
    println(tb)
    C:\temp>il_allegro
    > load("tb.ils")
    t
    > load("tb.ils")
    variable report_tb redefined
    t
    > pp report_tb
    foreach(symdef
    foreach(child
    (symdef->children)
    (child->textBlock)
    foreach(text
    (text->textBlock)
    foreach(tb
    sort(l_textblocks
    'axlStrcmpAlpNum
    println(tb)
    nil
    > exit
    C:\temp>
