  3. How to output all textblock used in board file
  • Replies 7
  • Views 17893
eric22
eric22 over 6 years ago
Hi All,
Is there any script available in order to make report for all the text blocks used in one design?
I want to standardize the text block for very design, before that I want to make some list what are the textblocks used and which class/subclass.
Thanks.
Eric
  • cdlep
    cdlep over 6 years ago
    l_symdef = axlDBGetDesign()->symdefs
    l_textblocks = nil
    foreach(symdef l_symdef
    l_child = symdef->children
    foreach(child l_child
    if(child->objType = "text" && child->textBlock then
    line = strcat(child->layer " " child->textBlock)
    unless(member( line l_textblocks)
    l_textblocks = cons(line l_textblocks)
    foreach(tb sort(l_textblocks 'axlStrcmpAlpNum)
    println(tb)
  • eric22
    eric22 over 6 years ago in reply to cdlep
    Ho Cdlep,
    Thanks for the reply, however i am not expert on skill file.
    Do you have the skill file that i can run?
    Eric
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    Eric,
    The example skill code provided by cdlep only looked at text within symbol definitions, so I added some code to also look at the text within the design itself, code shown below from the file "tb.ils" :
    procedure(report_tb()
    let((l_textblocks line)
    (l_textblocks = list())
    foreach(symdef
    ((axlDBGetDesign)->symdefs)
    foreach(child
    (symdef->children)
    if((child->objType = ("text" && (child->textBlock))) then
    (line = strcat((child->layer) " "
    (child->textBlock)
    unless(member(line l_textblocks)
    (l_textblocks = cons(line l_textblocks))
    foreach(text
    ((axlDBGetDesign)->text)
    if((text->objType = ("text" && (text->textBlock))) then
    (line = strcat((text->layer) " "
    (text->textBlock)
    foreach(tb
    sort(l_textblocks
    'axlStrcmpAlpNum
    println(tb)
    Below is the journal file entries showing how I loaded & ran the skill code ( the 2 commands are shown in Bold text ) :
    \i (00:00:21) skill '(load "tb.ils")'
    (00:00:21) t
    \i (00:00:37) skill (report_tb)
    (00:00:37) "BOARD GEOMETRY/DIMENSION 9"
    (00:00:37) "BOARD GEOMETRY/MP_OUTLINE 8"
    (00:00:37) "BOARD GEOMETRY/SILKSCREEN_BOTTOM 2"
    (00:00:37) "BOARD GEOMETRY/SILKSCREEN_TOP 24"
    (00:00:37) "BOARD GEOMETRY/SILKSCREEN_TOP 34"
    (00:00:37) "BOARD GEOMETRY/SILKSCREEN_TOP 50"
    (00:00:37) "DRAWING FORMAT/ALL_LAYERS_TL 37"
    (00:00:37) "DRAWING FORMAT/ALL_LAYERS_TL 55"
    (00:00:37) "DRAWING FORMAT/ASSY_BOTTOM 6"
    (00:00:37) "DRAWING FORMAT/ASSY_BOTTOM 12"
    (00:00:37) "DRAWING FORMAT/ASSY_BOTTOM 41"
    (00:00:37) "DRAWING FORMAT/ASSY_BOTTOM 63"
    (00:00:37) "DRAWING FORMAT/ASSY_BOTTOM 64"
    (00:00:37) "DRAWING FORMAT/ASSY_TOP 6"
    (00:00:37) "DRAWING FORMAT/ASSY_TOP 8"
    (00:00:37) "DRAWING FORMAT/ASSY_TOP 12"
    (00:00:37) "DRAWING FORMAT/ASSY_TOP 16"
    (00:00:37) "DRAWING FORMAT/ASSY_TOP 41"
    (00:00:37) "DRAWING FORMAT/ASSY_TOP 61"
    (00:00:37) "DRAWING FORMAT/ASSY_TOP 63"
    (00:00:37) "DRAWING FORMAT/ASSY_TOP 64"
    (00:00:37) "DRAWING FORMAT/ETCH_ALL_LAYERS_TL 7"
    (00:00:37) "DRAWING FORMAT/ETCH_ALL_LAYERS_TL 55"
    (00:00:37) "DRAWING FORMAT/ETCH_ALL_LAYERS_TL 56"
    (00:00:37) "DRAWING FORMAT/ETCH_GND1_TL 7"
    (00:00:37) "DRAWING FORMAT/ETCH_GND2_TL 7"
    (00:00:37) "DRAWING FORMAT/ETCH_GND3_TL 7"
    (00:00:37) "DRAWING FORMAT/ETCH_GND4_TL 56"
    (00:00:37) "DRAWING FORMAT/ETCH_GND_TL 56"
    (00:00:37) "DRAWING FORMAT/ETCH_INT1_TL 56"
    (00:00:37) "DRAWING FORMAT/ETCH_INT2_TL 56"
    (00:00:37) "DRAWING FORMAT/ETCH_INT3_TL 56"
    (00:00:37) "DRAWING FORMAT/ETCH_INT4_TL 56"
    (00:00:37) "DRAWING FORMAT/ETCH_PRIMARY_TL 56"
    (00:00:37) "DRAWING FORMAT/ETCH_PWR1_TL 7"
    (00:00:37) "DRAWING FORMAT/ETCH_PWR2_TL 7"
    (00:00:37) "DRAWING FORMAT/ETCH_SECONDARY_TL 56"
    (00:00:37) "DRAWING FORMAT/ETCH_VCC_TL 56"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 6"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 7"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 8"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 9"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 12"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 13"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 16"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 19"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 40"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 41"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 61"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 63"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 64"
    (00:00:37) "DRAWING FORMAT/FAB_SHT2 9"
    (00:00:37) "DRAWING FORMAT/FAB_SHT2 11"
    (00:00:37) "DRAWING FORMAT/FAB_SHT2 16"
    (00:00:37) "DRAWING FORMAT/FAB_SHT2 64"
    (00:00:37) "DRAWING FORMAT/LEGEND_PRIMARY_TL 55"
    (00:00:37) "DRAWING FORMAT/LEGEND_PRIMARY_TL 56"
    (00:00:37) "DRAWING FORMAT/LEGEND_SECOND_TL 55"
    (00:00:37) "DRAWING FORMAT/LEGEND_SECOND_TL 56"
    (00:00:37) "DRAWING FORMAT/MENTOR_ASSY 14"
    (00:00:37) "DRAWING FORMAT/MULTIPACK 4"
    (00:00:37) "DRAWING FORMAT/MULTIPACK 6"
    (00:00:37) "DRAWING FORMAT/MULTIPACK 8"
    (00:00:37) "DRAWING FORMAT/MULTIPACK 9"
    (00:00:37) "DRAWING FORMAT/MULTIPACK 10"
    (00:00:37) "DRAWING FORMAT/MULTIPACK 12"
    (00:00:37) "DRAWING FORMAT/MULTIPACK 13"
    (00:00:37) "DRAWING FORMAT/MULTIPACK 15"
    (00:00:37) "DRAWING FORMAT/MULTIPACK 16"
    (00:00:37) "DRAWING FORMAT/OUTLINE 4"
    (00:00:37) "DRAWING FORMAT/OUTLINE 10"
    (00:00:37) "DRAWING FORMAT/PASTE_PRIMARY_TL 55"
    (00:00:37) "DRAWING FORMAT/PASTE_PRIMARY_TL 56"
    (00:00:37) "DRAWING FORMAT/PASTE_SECONDARY_TL 55"
    (00:00:37) "DRAWING FORMAT/PASTE_SECONDARY_TL 56"
    (00:00:37) "DRAWING FORMAT/PBATP_ALL_LAYER_TL 55"
    (00:00:37) "DRAWING FORMAT/PBATP_ALL_LAYER_TL 56"
    (00:00:37) "DRAWING FORMAT/PBATP_PRIMARY_TL 55"
    (00:00:37) "DRAWING FORMAT/PBATP_PRIMARY_TL 56"
    (00:00:37) "DRAWING FORMAT/PBATP_SECONDARY_TL 55"
    (00:00:37) "DRAWING FORMAT/PBATP_SECONDARY_TL 56"
    (00:00:37) "DRAWING FORMAT/SM_PRIMARY_TL 55"
    (00:00:37) "DRAWING FORMAT/SM_PRIMARY_TL 56"
    (00:00:37) "DRAWING FORMAT/SM_SECONDARY_TL 55"
    (00:00:37) "DRAWING FORMAT/SM_SECONDARY_TL 56"
    (00:00:37) "DRAWING FORMAT/TITLE_BLOCK 16"
    (00:00:37) "DRAWING FORMAT/TITLE_BLOCK 41"
    (00:00:37) "DRAWING FORMAT/TITLE_BLOCK 61"
    (00:00:37) "DRAWING FORMAT/VIACAP_SEC_TL 55"
    (00:00:37) "DRAWING FORMAT/VIACAP_SEC_TL 56"
    (00:00:37) "ETCH/BOTTOM 2"
    (00:00:37) "ETCH/BOTTOM 3"
    (00:00:37) "ETCH/L10-SIGNAL 2"
    (00:00:37) "ETCH/L11-GND 2"
    (00:00:37) "ETCH/L12-SIGNAL 2"
    (00:00:37) "ETCH/L13-GND 2"
    (00:00:37) "ETCH/L2-GND 2"
    (00:00:37) "ETCH/L3-SIGNAL 2"
    (00:00:37) "ETCH/L4-GND 2"
    (00:00:37) "ETCH/L5-PWR 2"
    (00:00:37) "ETCH/L6-GND 2"
    (00:00:37) "ETCH/L7-PWR 2"
    (00:00:37) "ETCH/L8-PWR 2"
    (00:00:37) "ETCH/L9-GND 2"
    (00:00:37) "ETCH/TOP 2"
    (00:00:37) "MANUFACTURING/MENTOR_PADS 14"
    (00:00:37) "MANUFACTURING/NCBACKDRILL-14-11 9"
    (00:00:37) "MANUFACTURING/NCBACKDRILL-14-4 9"
    (00:00:37) "MANUFACTURING/NCLEGEND-1-14 9"
    (00:00:37) "PACKAGE GEOMETRY/ASSEMBLY_BOTTOM 33"
    (00:00:37) "PACKAGE GEOMETRY/ASSEMBLY_BOTTOM 34"
    (00:00:37) "PACKAGE GEOMETRY/ASSEMBLY_TOP 33"
    (00:00:37) "PACKAGE GEOMETRY/ASSEMBLY_TOP 34"
    (00:00:37) "PACKAGE GEOMETRY/ASSEMBLY_TOP 37"
    (00:00:37) "PACKAGE GEOMETRY/ASSEMBLY_TOP 42"
    (00:00:37) "PACKAGE GEOMETRY/ASSEMBLY_TOP 51"
    (00:00:37) "PACKAGE GEOMETRY/ASSEMBLY_TOP 52"
    (00:00:37) "PACKAGE GEOMETRY/ASSEMBLY_TOP 54"
    (00:00:37) "PACKAGE GEOMETRY/DIMENSION 35"
    (00:00:37) "PACKAGE GEOMETRY/DIMENSON 35"
    (00:00:37) "PACKAGE GEOMETRY/DISPLAY_TOP 34"
    (00:00:37) "PACKAGE GEOMETRY/LIBREV 35"
    (00:00:37) "PACKAGE GEOMETRY/LIB_REV 34"
    (00:00:37) "PACKAGE GEOMETRY/LIB_REV 35"
    (00:00:37) "PACKAGE GEOMETRY/LIB_REV 37"
    (00:00:37) "PACKAGE GEOMETRY/LIB_REV 39"
    (00:00:37) "PACKAGE GEOMETRY/LIB_REV 49"
    (00:00:37) "PACKAGE GEOMETRY/LIB_REV 50"
    (00:00:37) "PACKAGE GEOMETRY/LIB_REV 51"
    (00:00:37) "PACKAGE GEOMETRY/LIB_REV 53"
    (00:00:37) "PACKAGE GEOMETRY/LIB_REV 54"
    (00:00:37) "PACKAGE GEOMETRY/NOTES 34"
    (00:00:37) "PACKAGE GEOMETRY/NOTES 35"
    (00:00:37) "PACKAGE GEOMETRY/NOTES 37"
    (00:00:37) "PACKAGE GEOMETRY/NOTES 39"
    (00:00:37) "PACKAGE GEOMETRY/NOTES 49"
    (00:00:37) "PACKAGE GEOMETRY/NOTES 50"
    (00:00:37) "PACKAGE GEOMETRY/NOTES 51"
    (00:00:37) "PACKAGE GEOMETRY/NOTES 53"
    (00:00:37) "PACKAGE GEOMETRY/NOTES 54"
    (00:00:37) "PACKAGE GEOMETRY/PAD_STACK_NAME 35"
    (00:00:37) "PACKAGE GEOMETRY/SILKSCREEN_BOTTOM 33"
    (00:00:37) "PACKAGE GEOMETRY/SILKSCREEN_BOTTOM 34"
    (00:00:37) "PACKAGE GEOMETRY/SILKSCREEN_TOP 2"
    (00:00:37) "PACKAGE GEOMETRY/SILKSCREEN_TOP 33"
    (00:00:37) "PACKAGE GEOMETRY/SILKSCREEN_TOP 34"
    (00:00:37) "PACKAGE GEOMETRY/SILKSCREEN_TOP 51"
    (00:00:37) "PACKAGE GEOMETRY/SILKSCREEN_TOP 52"
    (00:00:37) "PACKAGE GEOMETRY/SILKSCREEN_TOP 54"
    (00:00:37) "REF DES/ASSEMBLY_BOTTOM 34"
    (00:00:37) "REF DES/ASSEMBLY_TOP 33"
    (00:00:37) "REF DES/ASSEMBLY_TOP 34"
    (00:00:37) "REF DES/ASSEMBLY_TOP 39"
    (00:00:37) "REF DES/ASSEMBLY_TOP 49"
    (00:00:37) "REF DES/ASSEMBLY_TOP 51"
    (00:00:37) "REF DES/ASSEMBLY_TOP 54"
    (00:00:37) "REF DES/SILKSCREEN_BOTTOM 33"
    (00:00:37) "REF DES/SILKSCREEN_TOP 33"
    (00:00:37) "REF DES/SILKSCREEN_TOP 34"
    (00:00:37) "REF DES/SILKSCREEN_TOP 49"
    (00:00:37) "REF DES/SILKSCREEN_TOP 51"
    (00:00:37) "REF DES/SILKSCREEN_TOP 54"
    (00:00:37) ("BOARD GEOMETRY/DIMENSION 9" "BOARD GEOMETRY/MP_OUTLINE 8" "BOARD GEOMETRY/SILKSCREEN_BOTTOM 2" "BOARD GEOMETRY/SILKSCREEN_TOP 24" "BOARD GEOMETRY/SILKSCREEN_TOP 34"
    (00:00:37) "BOARD GEOMETRY/SILKSCREEN_TOP 50" "DRAWING FORMAT/ALL_LAYERS_TL 37" "DRAWING FORMAT/ALL_LAYERS_TL 55" "DRAWING FORMAT/ASSY_BOTTOM 6" "DRAWING FORMAT/ASSY_BOTTOM 12"
    (00:00:37) "DRAWING FORMAT/ASSY_BOTTOM 41" "DRAWING FORMAT/ASSY_BOTTOM 63" "DRAWING FORMAT/ASSY_BOTTOM 64" "DRAWING FORMAT/ASSY_TOP 6" "DRAWING FORMAT/ASSY_TOP 8"
    (00:00:37) "DRAWING FORMAT/ASSY_TOP 12" "DRAWING FORMAT/ASSY_TOP 16" "DRAWING FORMAT/ASSY_TOP 41" "DRAWING FORMAT/ASSY_TOP 61" "DRAWING FORMAT/ASSY_TOP 63"
    (00:00:37) "DRAWING FORMAT/ASSY_TOP 64" "DRAWING FORMAT/ETCH_ALL_LAYERS_TL 7" "DRAWING FORMAT/ETCH_ALL_LAYERS_TL 55" "DRAWING FORMAT/ETCH_ALL_LAYERS_TL 56" "DRAWING FORMAT/ETCH_GND1_TL 7"
    (00:00:37) "DRAWING FORMAT/ETCH_GND2_TL 7" "DRAWING FORMAT/ETCH_GND3_TL 7" "DRAWING FORMAT/ETCH_GND4_TL 56" "DRAWING FORMAT/ETCH_GND_TL 56" "DRAWING FORMAT/ETCH_INT1_TL 56"
    (00:00:37) "DRAWING FORMAT/ETCH_INT2_TL 56" "DRAWING FORMAT/ETCH_INT3_TL 56" "DRAWING FORMAT/ETCH_INT4_TL 56" "DRAWING FORMAT/ETCH_PRIMARY_TL 56" "DRAWING FORMAT/ETCH_PWR1_TL 7"
    (00:00:37) "DRAWING FORMAT/ETCH_PWR2_TL 7" "DRAWING FORMAT/ETCH_SECONDARY_TL 56" "DRAWING FORMAT/ETCH_VCC_TL 56" "DRAWING FORMAT/FAB_SHT1 6" "DRAWING FORMAT/FAB_SHT1 7"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 8" "DRAWING FORMAT/FAB_SHT1 9" "DRAWING FORMAT/FAB_SHT1 12" "DRAWING FORMAT/FAB_SHT1 13" "DRAWING FORMAT/FAB_SHT1 16"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 19" "DRAWING FORMAT/FAB_SHT1 40" "DRAWING FORMAT/FAB_SHT1 41" "DRAWING FORMAT/FAB_SHT1 61" "DRAWING FORMAT/FAB_SHT1 63"
    (00:00:37) "DRAWING FORMAT/FAB_SHT1 64" "DRAWING FORMAT/FAB_SHT2 9" "DRAWING FORMAT/FAB_SHT2 11" "DRAWING FORMAT/FAB_SHT2 16" "DRAWING FORMAT/FAB_SHT2 64"
    (00:00:37) "DRAWING FORMAT/LEGEND_PRIMARY_TL 55" "DRAWING FORMAT/LEGEND_PRIMARY_TL 56" "DRAWING FORMAT/LEGEND_SECOND_TL 55" "DRAWING FORMAT/LEGEND_SECOND_TL 56" "DRAWING FORMAT/MENTOR_ASSY 14"
    (00:00:37) "DRAWING FORMAT/MULTIPACK 4" "DRAWING FORMAT/MULTIPACK 6" "DRAWING FORMAT/MULTIPACK 8" "DRAWING FORMAT/MULTIPACK 9" "DRAWING FORMAT/MULTIPACK 10"
    (00:00:37) "DRAWING FORMAT/MULTIPACK 12" "DRAWING FORMAT/MULTIPACK 13" "DRAWING FORMAT/MULTIPACK 15" "DRAWING FORMAT/MULTIPACK 16" "DRAWING FORMAT/OUTLINE 4"
    (00:00:37) "DRAWING FORMAT/OUTLINE 10" "DRAWING FORMAT/PASTE_PRIMARY_TL 55" "DRAWING FORMAT/PASTE_PRIMARY_TL 56" "DRAWING FORMAT/PASTE_SECONDARY_TL 55" "DRAWING FORMAT/PASTE_SECONDARY_TL 56"
    (00:00:37) "DRAWING FORMAT/PBATP_ALL_LAYER_TL 55" "DRAWING FORMAT/PBATP_ALL_LAYER_TL 56" "DRAWING FORMAT/PBATP_PRIMARY_TL 55" "DRAWING FORMAT/PBATP_PRIMARY_TL 56" "DRAWING FORMAT/PBATP_SECONDARY_TL 55"
    (00:00:37) "DRAWING FORMAT/PBATP_SECONDARY_TL 56" "DRAWING FORMAT/SM_PRIMARY_TL 55" "DRAWING FORMAT/SM_PRIMARY_TL 56" "DRAWING FORMAT/SM_SECONDARY_TL 55" "DRAWING FORMAT/SM_SECONDARY_TL 56"
    (00:00:37) "DRAWING FORMAT/TITLE_BLOCK 16" "DRAWING FORMAT/TITLE_BLOCK 41" "DRAWING FORMAT/TITLE_BLOCK 61" "DRAWING FORMAT/VIACAP_SEC_TL 55" "DRAWING FORMAT/VIACAP_SEC_TL 56"
    (00:00:37) "ETCH/BOTTOM 2" "ETCH/BOTTOM 3" "ETCH/L10-SIGNAL 2" "ETCH/L11-GND 2" "ETCH/L12-SIGNAL 2"
    (00:00:37) "ETCH/L13-GND 2" "ETCH/L2-GND 2" "ETCH/L3-SIGNAL 2" "ETCH/L4-GND 2" "ETCH/L5-PWR 2"
    (00:00:37) "ETCH/L6-GND 2" "ETCH/L7-PWR 2" "ETCH/L8-PWR 2" "ETCH/L9-GND 2" "ETCH/TOP 2"
    (00:00:37) "MANUFACTURING/MENTOR_PADS 14" "MANUFACTURING/NCBACKDRILL-14-11 9" "MANUFACTURING/NCBACKDRILL-14-4 9" "MANUFACTURING/NCLEGEND-1-14 9" "PACKAGE GEOMETRY/ASSEMBLY_BOTTOM 33"
    (00:00:37) "PACKAGE GEOMETRY/ASSEMBLY_BOTTOM 34" "PACKAGE GEOMETRY/ASSEMBLY_TOP 33" "PACKAGE GEOMETRY/ASSEMBLY_TOP 34" "PACKAGE GEOMETRY/ASSEMBLY_TOP 37" "PACKAGE GEOMETRY/ASSEMBLY_TOP 42"
    (00:00:37) "PACKAGE GEOMETRY/ASSEMBLY_TOP 51" "PACKAGE GEOMETRY/ASSEMBLY_TOP 52" "PACKAGE GEOMETRY/ASSEMBLY_TOP 54" "PACKAGE GEOMETRY/DIMENSION 35" "PACKAGE GEOMETRY/DIMENSON 35"
    (00:00:37) "PACKAGE GEOMETRY/DISPLAY_TOP 34" "PACKAGE GEOMETRY/LIBREV 35" "PACKAGE GEOMETRY/LIB_REV 34" "PACKAGE GEOMETRY/LIB_REV 35" "PACKAGE GEOMETRY/LIB_REV 37"
    (00:00:37) "PACKAGE GEOMETRY/LIB_REV 39" "PACKAGE GEOMETRY/LIB_REV 49" "PACKAGE GEOMETRY/LIB_REV 50" "PACKAGE GEOMETRY/LIB_REV 51" "PACKAGE GEOMETRY/LIB_REV 53"
    (00:00:37) "PACKAGE GEOMETRY/LIB_REV 54" "PACKAGE GEOMETRY/NOTES 34" "PACKAGE GEOMETRY/NOTES 35" "PACKAGE GEOMETRY/NOTES 37" "PACKAGE GEOMETRY/NOTES 39"
    (00:00:37) "PACKAGE GEOMETRY/NOTES 49" "PACKAGE GEOMETRY/NOTES 50" "PACKAGE GEOMETRY/NOTES 51" "PACKAGE GEOMETRY/NOTES 53" "PACKAGE GEOMETRY/NOTES 54"
    (00:00:37) "PACKAGE GEOMETRY/PAD_STACK_NAME 35" "PACKAGE GEOMETRY/SILKSCREEN_BOTTOM 33" "PACKAGE GEOMETRY/SILKSCREEN_BOTTOM 34" "PACKAGE GEOMETRY/SILKSCREEN_TOP 2" "PACKAGE GEOMETRY/SILKSCREEN_TOP 33"
    (00:00:37) "PACKAGE GEOMETRY/SILKSCREEN_TOP 34" "PACKAGE GEOMETRY/SILKSCREEN_TOP 51" "PACKAGE GEOMETRY/SILKSCREEN_TOP 52" "PACKAGE GEOMETRY/SILKSCREEN_TOP 54" "REF DES/ASSEMBLY_BOTTOM 34"
    (00:00:37) "REF DES/ASSEMBLY_TOP 33" "REF DES/ASSEMBLY_TOP 34" "REF DES/ASSEMBLY_TOP 39" "REF DES/ASSEMBLY_TOP 49" "REF DES/ASSEMBLY_TOP 51"
    (00:00:37) "REF DES/ASSEMBLY_TOP 54" "REF DES/SILKSCREEN_BOTTOM 33" "REF DES/SILKSCREEN_TOP 33" "REF DES/SILKSCREEN_TOP 34" "REF DES/SILKSCREEN_TOP 49"
    (00:00:37) "REF DES/SILKSCREEN_TOP 51" "REF DES/SILKSCREEN_TOP 54"
    (00:00:37) )
    \i (00:01:05) exit
  • eric22
    eric22 over 6 years ago in reply to DavidJHutchins
    Hi David,
    Greatly appreciated your reply with the code. Thanks much.
    Should i copy this code into notepad and run it as it is?
    regards,
    eric
  • DavidJHutchins
    From within Allegro, enter the command 'shell' to launch a 'command line' window in your design folder
    from that window enter the command 'Notepad' to start text editor, paste the section of code into it & save it as 'tb.ils'
    Now back in Allegro enter the 2 commands in bold from my last posting
