  3. How to view a PCB in an earlier version (OrCAD 17.2) which...
  • Subscribers 166
  • Views 23332
How to view a PCB in an earlier version (OrCAD 17.2) which was designed using a later version (OrCAD 17.4) ?
johnbbsr
johnbbsr over 6 years ago
I am new to using OrCAD and my colleague has designed a PCB using OrCAD 17.4, but I only have OrCAD 17.2.
Is there any way I can view this PCB design without having to upgrade to 17.4 (which is not an option at the moment) ?
Can my colleague save the PCB as an earlier version that's compatible with version 17.2 (much like Office tools where you can save as earlier Word versions etc) ?
Or can he convert or export the design so that's compatible with version 17.2 ?
Or is there a tool (online/plugin/app) that can convert the PCB to a format that's compatible ?
I have used PADS, Altium, Proteous, EasyPC and DesignSpark in the past but never OrCAD so I am about to start the online tutorials.
  • DavidJHutchins
    DavidJHutchins over 6 years ago +1
    I think the simplest solution would be for you to download & install the stand-alone 17.4 allegro_free_viewer, which doesn't affect your current 17.2 installation
  • Quist
    Quist over 6 years ago +1
    In 17.4, if you select the DSN-file in the project manager-window and then File -> Save as you can change the type to "Capture 16.2 Design" which 17.2 should be able to open.
  • AvengerThanos
    AvengerThanos over 6 years ago +1
    Hi, OrCAD PCB 17.4 has the option File - Export - Downrev, which helps to export the 17.2 version from 17.4. Ask your colleague to down rev design and send you.
  • DavidJHutchins
  • Quist
  • AvengerThanos
  • Fran D
    Fran D over 6 years ago in reply to AvengerThanos
    I'm using 17.4, but I don't see Downrev as an option in File - Export. I'm also at S007. Was this utility removed?
  • redwire
    redwire over 6 years ago in reply to Fran D
    I can see it in my version of 17.4HF007
