  3. zcopy question
  • Subscribers 167
  • Views 15593
zcopy question
masamasa
masamasa over 6 years ago
hello
is there a way to copy an object to two or more layers at once?
i use a zcopy command to copy an object to a different layer.
but i would like to find out if i can do it not to a single layer but to multiple layers at once.
  • B Bruekers
    B Bruekers over 6 years ago
    If you want to copy to each ETCH subclass for example, just fill in an astrix (*) in the subclass drop-down box instead of selecting the subclass layer.
  • masamasa
    masamasa over 6 years ago in reply to B Bruekers
    thank you for your reply.
    wow, it works now amaizingly.
    that saves me lots of time.
    thank you again.
  • steve
    steve over 6 years ago
    If you invoke Shape Edit Mode, hover over the shape you want to copy and right click - Copy to Layers... you can choose the layer(s) you want to copy to and they are copied.
  • masamasa
    masamasa over 6 years ago in reply to steve
    wow, thank you steve.
    it works fine as well.
    thank you again.
