  3. How to get the location of Assembly Line
  • Views 17639
Thinker5112
Thinker5112 over 6 years ago
Hi
I'm trying to find the location of the assembly line in the design automatically without using "Show Element". And also I want to find the end points of that line. The line exists in "Package Geometry/Assembly_Top" Layer. So is there any code snippet to find the location of assembly line?
  • DavidJHutchins
    DavidJHutchins over 6 years ago +1
    procedure(report_line() let((line_id start_end) (axlSetFindFilter ?enabled list("noall" "lines" ) ?onButtons list("noall" "lines")) (line_id = car((axlGetSelSet (axlSingleSelectPoint)))) when(line_id foreach…
  • DavidJHutchins
    when(line_id
    foreach(seg (line_id->segments)
    (start_end = seg->startEnd)
    when(((seg->objType) == "line")
    axlMsgPut("line start (%.4f:%.4f) end (%.4f:%.4f)\n" car(car(start_end)) cadr(car(start_end)) car(cadr(start_end)) cadr(cadr(start_end)))
    when(((seg->objType) == "arc")
    axlMsgPut("arc start (%.4f:%.4f) center (%.4f:%.4f) end (%.4f:%.4f)\n" car(car(start_end)) cadr(car(start_end)) car(seg->xy) cadr(seg->xy) car(cadr(start_end)) cadr(cadr(start_end)))
  • Thinker5112
    Thinker5112 over 6 years ago in reply to DavidJHutchins
    Hi David, thank you for your support.
  • Thinker5112
    Hi David, is there any way to select the assembly line without using axlGetSelSet and axlSingleSelectPoint? I mean to ask, can we automatically select an assembly line without using any of those functions?
  • DavidJHutchins
    I think you need to do some sort of selection command, perhaps you could replace the line:
    with the following to select the first line found on the current screen:
    (line_id = car((axlGetSelSet (axlAddSelectBox(axlWindowBoxGet)))))
