  3. DRC Problem after updating trace width - now won't go a...
  • Subscribers 166
  • Views 6036
DRC Problem after updating trace width - now won't go away
Justin Loop
Justin Loop over 6 years ago
I have an interesting problem.  I have eight (8) connectors on a PCB. One, for some reason, is giving me problems.  I am getting a DRC problem.  I have NO IDEA why I am getting this problem.  Here is some picture for a better understanding:
I have no idea how to fix this problem.  Please provide a STEP BY STEP resolution to fix this.  All other connectors are just fine.
Thank you.
JTL
  • mcatramb91
    mcatramb91 over 6 years ago +1
    Hello, It looks like you have a text string (" 1 ") sitting inside of the pad boundary on the Bottom Etch Layer which is causing the DRCs. Using Check > Element (Show Element) with only Text enabled…
  • Justin Loop
    Justin Loop over 6 years ago in reply to mcatramb91
    mcatramb91, you are a rock star. Thank you.  All is good. Sorry I was unable to get back to your earlier. I have been working on other projects. This worked.
