  3. GND and VCC planes not assigned to GND VCC Nets
  • Replies 17
  • Views 27020
Cailloux
Cailloux over 6 years ago
Schematic NETLIST is generated without any error. I can Import into PCB Editor from Import > Logic with no error. On my Schematic I have a GND Net and a VCC Net as well as many other Nets. The Cross Section is comprised of TOP, GND, VCC, BOTTOM ( 4 layers ).  GND layer has been assigned to the GND Net and VCC layer to VCC Net, using the creation of rectangular Shape creation, as directed in the Allegro PCB Editor Training Manual. Placing is complete and no DRC error shows up. I am ready to AutoRoute the board.
Everything goes quite well and the Board is now routed, still no DRC errors shows up.
Yet, I clearly see GND segments on the TOP and BOTTOM layers as well as VCC segments on the TOP and BOTTOM layers. It’s as if the AutoRouter did not observe the VCC Net to VCC plane assignment nor GND Net to GND plane assignment. Net Assignments to Plane where performed without error and Shape colors appeared on the screen after completion, so I have no reason to suspect the assignment went wrong.If I transfer a TOP net segment to BOTTOM where a GND segment is crossing, I get a DRC error clearly showing that both segments are in contact. Which clearly indicate that this GND segment is located on the BOTTOM layer.
What Im I doing wrong  ?  What can be the source of this problem ?
  • Cailloux
    Cailloux over 6 years ago in reply to Lennie
    From which part did you see that? I looked at C22 pin 2 pad, a GrouNDed pin.  PAD44CIR34D  Drill is 36 and Default Internal Regular Pad is Circle 54 ( a bigger ring then drill)  . That is a pad that I modified. Added pad and footprint files to Google Drive in case you want to see them.
    I did peak at PAD44CIR33 in the original library, not modified. The pad designer show drill size 33mils and Default Internal Regular Pad is Circle 33 ( ring and drill same size ) . I understand why such situation could create a problem, still this is an original unmodified pad, another puzzle to clarify later.
    I still don’t see what is wrong with PAD44CIR34D. The Inner pad is bigger than the drill isn’t it?
    By the way, related to the autorouting I do get an electrical connection on one pin. That pin that was chosen when I attached the shape to net, using Select Shape or Void command and RMB Assign Net. Still the autorouter wiil route all other GND pins.
  • Lennie
    Lennie over 6 years ago in reply to Cailloux
    If you select the pin C22.2 / right click  mouse button / modify design padstack/single instance the padstack editor will come up. Look under design layers and you will see the outer layers are 54 and the inner are 36. They are the same size as the drill.
  • Lennie
    Lennie over 6 years ago in reply to Lennie
    Here is a picture.
  • CadAce2K
    CadAce2K over 6 years ago in reply to Cailloux
    Hi. Lennie is correct. A few of your padstacks don't have the inner layers set to make a connection. Simply turn on the GND layer and where you see a ratsnest, edit the padstack and make the inner layer pad the same as top/bottom, or slightly smaller. Same with 12V layer. To connect the GND signals, you need to drag a trace off the J1 pads and drop a via (add connect/click the pad, come off some, and double-click). Done. Easy. Same with a few 12V pads; add connect, come off the pad, double-click a via connection. (Hint, when routing, RMB - turn off Enhanced Pad connect. Quite unnecessary). Aside from that, you can 'slide' traces around and make it look nicer. I note you didn't run a '45 degree' clean pass in  the autorouter. Easy to change traces to 45 degrees though. Simple board, take about 15 minutes and looks much nicer. Easy-peasy.
  • Cailloux
    Cailloux over 6 years ago in reply to CadAce2K
    Thanks Lennie and CadAce2k. It's obvious to me now where the problem is. I have absolutely not given any attention to the pad structure during this continuous learning spree. Now I need to redo all parts package with revised pads. One problem that occur when I try to use the Modify Design Padstack > Single Instance or All Instances. The Pad Editor opens and I do the corrections but when I save the PAD44CIR34D file and Close the Pad Editor, Even after saving my *.brd file, close PCB Editor, re-open and then check the pads on C22 for example, well, the pads have not changed. I tried Tools > Database Check, I tried Update DRC, yet no pads are updated to the new changes made in Pad Designer. There has got to be a procedure that I am missing in order to update those pads, Any thoughts ?
