  3. GND and VCC planes not assigned to GND VCC Nets
  • Replies 17
  • Views 27026
Cailloux
Cailloux over 6 years ago
Schematic NETLIST is generated without any error. I can Import into PCB Editor from Import > Logic with no error. On my Schematic I have a GND Net and a VCC Net as well as many other Nets. The Cross Section is comprised of TOP, GND, VCC, BOTTOM ( 4 layers ).  GND layer has been assigned to the GND Net and VCC layer to VCC Net, using the creation of rectangular Shape creation, as directed in the Allegro PCB Editor Training Manual. Placing is complete and no DRC error shows up. I am ready to AutoRoute the board.
Everything goes quite well and the Board is now routed, still no DRC errors shows up.
Yet, I clearly see GND segments on the TOP and BOTTOM layers as well as VCC segments on the TOP and BOTTOM layers. It’s as if the AutoRouter did not observe the VCC Net to VCC plane assignment nor GND Net to GND plane assignment. Net Assignments to Plane where performed without error and Shape colors appeared on the screen after completion, so I have no reason to suspect the assignment went wrong.If I transfer a TOP net segment to BOTTOM where a GND segment is crossing, I get a DRC error clearly showing that both segments are in contact. Which clearly indicate that this GND segment is located on the BOTTOM layer.
What Im I doing wrong  ?  What can be the source of this problem ?
  • Cailloux
    Cailloux over 6 years ago in reply to Cailloux
    Never mind, I just found the solution. Place > Update Symbols.
    Now I will re-autoroute and see.  thanks Again !
  • CadAce2K
    CadAce2K over 6 years ago in reply to Cailloux
    Hi. The only mistake you made (and all your other steps were fine) was when in the padstack editor, before you save/exit, is to "Update the padstacks in the database" (File/Update to Design). Do that and it will save the change to your database. -Regards.
  • Cailloux
    Cailloux over 6 years ago in reply to CadAce2K
    Done that too. Still didnt work ?  I would certainly appreciate you take a look at my next posted question regarding this GND connection problem. I have a feeling there is something more interfering with my autorouter.
  • CadAce2K
    Hi. What's your "next posted question"?
  • Cailloux
    Just completed now. Thanks
