  3. GND and VCC planes not assigned to GND VCC Nets
  • Replies 17
  • Views 27035
Cailloux
Cailloux over 6 years ago
Schematic NETLIST is generated without any error. I can Import into PCB Editor from Import > Logic with no error. On my Schematic I have a GND Net and a VCC Net as well as many other Nets. The Cross Section is comprised of TOP, GND, VCC, BOTTOM ( 4 layers ).  GND layer has been assigned to the GND Net and VCC layer to VCC Net, using the creation of rectangular Shape creation, as directed in the Allegro PCB Editor Training Manual. Placing is complete and no DRC error shows up. I am ready to AutoRoute the board.
Everything goes quite well and the Board is now routed, still no DRC errors shows up.
Yet, I clearly see GND segments on the TOP and BOTTOM layers as well as VCC segments on the TOP and BOTTOM layers. It’s as if the AutoRouter did not observe the VCC Net to VCC plane assignment nor GND Net to GND plane assignment. Net Assignments to Plane where performed without error and Shape colors appeared on the screen after completion, so I have no reason to suspect the assignment went wrong.If I transfer a TOP net segment to BOTTOM where a GND segment is crossing, I get a DRC error clearly showing that both segments are in contact. Which clearly indicate that this GND segment is located on the BOTTOM layer.
What Im I doing wrong  ?  What can be the source of this problem ?
  • CadAce2K
    CadAce2K over 6 years ago in reply to Cailloux
    Hi. Aside from the padstack issue (pads to small for the drill on your inner layers), the autorouter may not be routing the GND/+12V because of property settings. Again though, simply add connect/click on the surface mount pins for GND/+12V; go away from the pad and double-click a via in. Either that, or the auto-router session is not understanding your vias.
  • Cailloux
    Cailloux over 6 years ago in reply to CadAce2K
    I ran this little experiment. One DIP8_3, one RES400 , one capck05 packages. These packages being genuine, original from a fresh installation, not modified but verified with the Padstack editor. The board is comprised of one GND plane, one VCC plane, a very simple logic imported from Capture. The circuit is comprised of 5 Nets, which 2 of them being VCC and GND. The two planes are appropriately assigned to GND and VCC nets.
    Using the Automatic Router from Allegro PCB Editor, here are my conclusions following a lot of experimenting:
    If the [Automatic Router] is not specifically instructed to [Option > Limit via creation] , it will profusely utilize Vias to connect grounded or power nets to their respective plane layers. I am definitely missing something, for instead it would certainly be more appropriate to directly use the defined [Default Internal Pad] of a Pin within the Package instead of utilizing a Via to connect to the plane.
    It would be much appreciated if anyone with more experience can lead me to tips and tricks to better understand the situation. Cheers and thank you for any hints.
