  3. Get Form Path
  • Views 16019
Get Form Path
leto
leto over 6 years ago
Hello All,
Is there a SKILL function to obtain the Form path (similar to getSkillPath).
If not, is the a workaround to obtain the Form path?
Thanks All
  • cdlep
    cdlep over 6 years ago
    You set your Allegro PCB Editor environment variable FORMPATH in your env file. if you need to get it use: skill axlGetVariable("formpath") .  Must be set first though.
  • leto
    leto over 6 years ago in reply to cdlep
    Thanks Cdlep!
